Im stuck Please Help (DCL)
I'm stuck and cant find a solution.
I'm writing a lisp w/ DCL that will draw tee supports. I've got the list to show up in my DCL, but when you select a steel size, its not setting any values that I've stored.
Right now I only have 2 steel sizes in the program to try and simplify it.
Can someone please point me in the right direction?
Some areas I'm sure aren't correct:
User Input not storing the value
(set_tile "toselev" "000.000")
(mode_tile "toselev" 0)
(action_tile "toselev" "(setq TOSEL $value)")
Recalling Steel Sizes
(if userclick
(progn
(setq $COLSIZE$ (fix $COLSIZE$))
(setq $COLSIZE$ (nth $COLSIZE$ column))
(setq $BMSIZE$ (fix $BMSIZE$))
(setq $BMSIZE$ (nth $BMSIZE$ beam))
) Setting Variables for Steel Sizes
(defun info () ((= $COLSIZE$ "W5X19") (SETQ COLDEPTH 5.13) (SETQ COLFLGTHK 0.44) (SETQ PLTDEPTH 0.75) (SETQ PLTWIDTH 12.0) )
