Im stuck Please Help (DCL)
Jonathan3891
Advisor Advisor
Jonathan3891
I'm stuck and cant find a solution.
I'm writing a lisp w/ DCL that will draw tee supports. I've got the list to show up in my DCL, but when you select a steel size, its not setting any values that I've stored.
Right now I only have 2 steel sizes in the program to try and simplify it.
Can someone please point me in the right direction?
Some areas I'm sure aren't correct:
User Input not storing the value
      (set_tile "toselev" "000.000")
      (mode_tile "toselev" 0)
      (action_tile "toselev" "(setq TOSEL $value)")
Recalling Steel Sizes
    (if userclick
	(progn
	  (setq $COLSIZE$ (fix $COLSIZE$))
	  (setq $COLSIZE$ (nth $COLSIZE$ column))
	  (setq $BMSIZE$ (fix $BMSIZE$))
	  (setq $BMSIZE$ (nth $BMSIZE$ beam))
Setting Variables for Steel Sizes
 (defun info ()
	     ((= $COLSIZE$ "W5X19")
	     (SETQ COLDEPTH 5.13)
	     (SETQ COLFLGTHK 0.44)
	     (SETQ PLTDEPTH 0.75)
	     (SETQ PLTWIDTH 12.0)
Jonathan Norton
Blog | Linkedin
paullimapa
First of all, your lisp code calls for a slide file with an embedded path of "i:/acad/lisp/tpole2.sld".  Since this is not included in your attachments, test loading the lisp routine will fail.
Second, for your action_tile statement, why did you include functions: (strcat & (progn ?
I would drop these out and just use:
(action_tile "accept" "(setq $COLSIZE$ (atof (get_tile \"column\")))(setq $BMSIZE$ (atof (get_tile \"beam\")))(done_dialog)(setq userclick1 T)")
Thirdly, you are checking to see (if userclick is set.  I don't see this anywhere in your code.  I only see (setq userclick1 T).  So perhaps you should change it to test for: (if userclick1
Area Object Link | Attribute Modifier | Dwg Setup | Feet-Inch Calculator
Layer Apps | List on Steroids | VP Zoom Scales |Exchange App Store
Paul Li
IT Specialist
@The Office
scot-65
The $value returned is a zero-based index of the current position of the list box or popup list.
IT IS ALSO RETURNED AS A STRING. You will need to convert this into the list you have.
For example:
(setq a (list "12" "13" "14"))
and you populate a list box with the start_list sequence.
When you get the $value of the highlighted line, for instance
the user selects the line that reads "13", the value returned is "1".
(setq b $value)
To convert this, try (nth (atoi b) a)
I personally would not approach the problem in this manner.
My plan of attack is to create a list the moment the OK button is pressed.
It's like taking a snapshot of the DCL at closing time.
(action_tile "accept" "(User_GET)(done_dialog 1)")
(setq sd (start_dialog))
will allow one to enter the "main" part of the program:
(if (= sd 1)...
I also see that you do not set_tile of either of these lists.
What happens here is a empty string will be returned if nothing is selected.
(set_tile "Column" "0")
(set_tile "Beam" "1")
These can be part of your initialization/set tile sequence.
Have a look at my standard LSP file when beginning DCL programs.
You will find it is organized in a logical manner.
Good Luck!
Scot-65
A gift of extraordinary Common Sense does not require an Acronym Suffix to be added to my given name.
