Vector PAN on MVIEWs of LAYOUTs
braudpat
Mentor Mentor
Message 1 of 15
braudpat
Hello
1) Please see the attached DWG ...It's a Map Drawing which has been re-projected ...
NOTE: You can see the real DWG at the center of the North Circle !
2) And of course the MVIEWs of ALL Layouts are EMPTY because very far !
3) South Circle = OLD XY - North Circle = NEW XY
And I drew a LINE ( = the move vector ) !
Thus I am looking for a Lisp routine which will do an kind of AutoPan (= the move vector) into :
( So a question please ! )
- either ALL MViews of ALL Layout
- or ALL MViews of ONE specific Layout
The move vector could be indicated by 2 CLICs with the mouse (IDEM a distance)
or on keyboard something like : @6733809.37<89.56  ( = Length and Angle of the LINE between the 2 circles)
And if possible, if we are into the Object Space : maybe CLIC on the LINE ( = the move vector )
Do you see that I mean ??
At the end, the MVIEWs into the LAYOUTs must show the real DWG ...
Thanks in advance, THE HEALTH (Stay Safe), Regards, Patrice (The Old French EE Froggy)
Patrice ( Supporting Troops ) - Autodesk Expert Elite
If you are happy with my answer please mark "Accept as Solution" and if very happy please give me a Kudos (Felicitations) - Thanks
Patrice BRAUD
Accepted solutions (3)
Replies (14)
Message 2 of 15
ВeekeeCZ
Hi @braudpat
know/tried THIS  from CAD Studio?
Message 3 of 15
braudpat
Hello
YES Thanks I know this beautiful VLX !
But it can move ONLY the MVIEWs of ONE Layout !
And you must be into the Layout : OK for me ...
1) I would like ALSO almost the same routine for ALL Layouts ...
2) And (if possible) remain into the Object space and indicate the move vector
or CLIC on a LINE (which is the move vector) ...
<<< So my dream is >>>
Question : Which specific Layout (Acceptable for me to be into the specific Layout) or ALL Layouts (Default = ALL) : ?
Being into Object Space or into Layout Space
Please indicate the move vector (or CLIC on a LINE) : ?
For the move vector, with keyboard something like : 6733809.37<89.563
Thanks in advance, Regards, Patrice
Patrice BRAUD
Message 4 of 15
ВeekeeCZ
Also found this on my hdd... probably already posted somewhere...
I know... your dreams are a bit more complex... but one step after another.
(defun c:PanAllVPs (/ pt1 pt2 oCTAB en vp i ss vp)
  (if (and (setq pt1 (getpoint "\nSpecify 1st point: "))
	   (setq pt2 (getpoint "\nSpecify 2nd point: ")))
    (progn
      (setq oCTAB (getvar 'CTAB))
      (foreach x (layoutlist)
	(setvar 'CTAB x)
	(command "_.zoom" "_E")
	(if (setq ss (ssget "_X" (list '(0 . "VIEWPORT") (cons 410 x))))
	  (repeat (setq i (sslength ss))
	    (setq en (entget (ssname ss (setq i (1- i))))
		  vp (cdr (assoc 69 en)))
	    (if (> vp 1)
	      (progn
		(command "_.mspace")
		(setvar 'CVPORT vp)
		(command "_.PAN" pt1 pt2)))))
	(command "_.pspace"))
      (setvar 'CTAB oCTAB)))
  (princ)
Message 5 of 15
pbejse
(defun c:demo ( / Old_XY NEW_XY vpts in ve cvn)
      	(setq Old_XY '(596549.0 134871.0 0.0)
	     NEW_XY '(647922.0 6.86848e+06 0.0))
	(if
           (and  (= 0 (getvar "tilemode"))
                 (setq vpts (ssget "X" (list (cons 0 "VIEWPORT")(cons 410 (getvar 'ctab))
                                             (cons 8 "ZZZ_FENETRE"))))
	  (repeat (setq in (sslength vpts))
                      (setq ve (ssname vpts (setq in (1- in))))
        	      (setq cvn (cdr (Assoc 69 (entget ve))))
                      (if (>  cvn 1)
                          (progn
				(command "_MSPACE")
				(setvar "CVPORT" cvn)
				(command "_ucs" "_World")
				(command "-pan"  "_non" NEW_XY "_non"  Old_XY)
				(command "_PSPACE")
      (princ)
Oops too slow 😁
Also it needs to be for all layout tab.. 🙂 anyhoo @ВeekeeCZ  posted first, no point in modfying this code then
Message 6 of 15
braudpat
Hello @pbejse
THANKS your Lisp routine is OK when I am into a Layout ! ... which will be processed ...
with the absolute vector written into your routine ...
So please could you improve the routine a little bit ?
- Ask for a vector on keyboard - something like : @6733809.37<89.563
or First Point / Second Point
No need to CLIC on a reference LINE as into my sample DWG !
- Ask for ALL Layouts (Yes/No) Default = Yes : ?
PLEASE don't filter the MVIEW Layer : (cons 8 "ZZZ_FENETRE")
Because MVIEW can be on any layer ! Layers UNLOCKED I presume !!
Patrice BRAUD
Message 7 of 15
braudpat
Hello @ВeekeeCZ
SORRY but your routine is NOK for me !
Or I am a stupid boy !? Maybe because I am tired this evening !!
Have you used your Lisp routine on my test DWG with success ??
Thanks for your effort, Regards, Patrice
Patrice BRAUD
Message 8 of 15
pbejse
@braudpat wrote:
Hello @pbejse
How would want to proceed if the  reply is NO?
Understood.
Message 9 of 15
braudpat
Hello @pbejse
I have an easy solution :  Must be into A Layout
-- If Process ALL Layouts (Default Option) : GO
-- If NOT, process ONLY the CURRENT Layout
PS: I will be back into 2 hours about ... Because it's dinner time with friends ...
Patrice BRAUD
Message 10 of 15
pbejse
Here you go,.. I combined @ВeekeeCZ  and my post  to adapt to your requirements.
(defun c:VPML ( / _TheProcess _FromTo opt oCTAB pt)
;;	pBe | Z9E3zK5E July 2020		;;;
(Defun _TheProcess ( layt p1 p2 / vpts ve cvn )
  	(command "_-Vports" "_Lock" "_Off" "_All" "")
	(if (setq vpts (ssget "X"
				    (cons 410 layt)
	    (setq ve  (entget (ssname vpts (setq in (1- in))))
		  cvn (cdr (assoc 69 ve))
	    (if	(> cvn 1)
	      (progn
		(command "_MSPACE")
		(command "-pan" "_non" p1 "_non" p2)
		(command "_PSPACE")
(command "_-Vports" "_Lock" "_On" "All" "")
(defun _FromTo ( / Old_XY NEW_XY)
	(if (and
	      	(setq Old_XY (getpoint "\nSpecify Old XY: "))
		(setq NEW_XY (getpoint Old_XY "\nSpecify NEW XY: ")))
	  (list NEW_XY Old_XY ))
(initget "Yes Current")
(setq opt (getkword "\nProcess ALL Layouts (Yes/Current)< Yes > : "))
(setq opt (if (null opt) "Yes" opt))
(cond
  (	(eq "Yes" opt)
	  (setvar 'tilemode 1)
	  (Setq pt (_FromTo))
		(setvar 'CTAB x)
		(_TheProcess x  (Car pt) (cadr pt))
  (	(and (eq "Current" opt)(zerop (getvar 'Tilemode)))
   		(Setq pt (_FromTo))
   		(setvar 'ctab oCTAB)
   	(_TheProcess oCTAB  (Car pt) (cadr pt))
  (	(alert "\n <<< Not a layout tab >>>")
  (princ)
 HTH
Save some for us 😊
Message 11 of 15
ВeekeeCZ
Well, I did just a quick test before leaving the office and it seemed to be working. The was a trick that you need to pick the new point first, then the old. Sorry about that, @braudpat
Anyway, @pbejse it's all yours.
Message 12 of 15
pbejse
FWIW it does work @ВeekeeCZ . I suspect @braudpat  point selection is not in the correct order, me thinks.
Happy weekend to you. 🙂
Message 13 of 15
ВeekeeCZ
Just one more note,  @braudpat  do some testing on large files and check all VP if there are PANed correctly.
I think, there were some issues with retrieving VP's ID... and therefore I added a ZOOM to each layout to make sure that all VPs are reloaded. Possibly zoom extents/previous.
Cheers guys! Have a great weekend both!
Message 14 of 15
ronjonp
Here is my offering. 🍻
(defun c:foo (/ a c d f np o p1 p2 v sc x)
  ;; RJP » 2020-06-26
  ;; Move all viewport centers from one picked point to another
  (if (and (setq p1 (getpoint "\nPick OLD center point: "))
	   (setq p2 (getpoint p1 "\nPick NEW center point: "))
	   (setq v (ssget "_X" '((0 . "VIEWPORT") (-4 . "!=") (69 . 1))))
	   (setq d (vla-get-activedocument (setq a (vlax-get-acad-object))))
    (foreach vp	(mapcar 'cadr (ssnamex v))
      (cond ((vlax-write-enabled-p (setq o (vlax-ename->vla-object vp)))
	     (setvar 'ctab (cdr (assoc 410 (entget vp))))
	     (cond ((> (setq c (cdr (assoc 69 (entget vp)))) 1)
		    (and (setq f (= -1 (vlax-get o 'displaylocked))) (vlax-put o 'displaylocked 0))
		    (vlax-put d 'mspace -1)
		    (setvar 'cvport c)
		    (setq sc (vla-get-customscale o))
		    (setq np (polar (getvar 'viewctr) (angle p1 p2) (distance p1 p2)))
		    (vla-zoomcenter a (vlax-3d-point np) 1.)
		    (vla-put-customscale o sc)
		    (and f (vlax-put o 'displaylocked -1))
		    (vlax-put d 'mspace 0)
  (princ)
Message 15 of 15
braudpat
Hello @ВeekeeCZ , @pbejse , @ronjonp
1) THANKS everybody ! ... Yours 3 routines are OK !!
2) THANKS for your effort & attention !
THE HEALTH (Stay Safe), Happy WE, Regards, Patrice (The Old French EE Froggy)
Patrice BRAUD
