Filedia Not working in 2021
vincent
Message 1 of 8
vincent
From Upgrading from AutoCAD 2020 to AutoCAD 2021, I have found that the Filedia is not working on a customised routine.
In AutoCAD2020 when setting the filedia to “0” it Does not display dialog boxes.
In AutoCAD2021 still setting Filedia to “0” using the same routine it brings the display dialog boxes.
Please see routines below. And screen cast
AutoCad2020
Command: -insert
Enter block name or [?] <A1 Title Block>: "W:/Cad Dept/CAD Data/Block Library/Title Blocks/Blank Block Files/A1 Landscape Title Block"
Units: Millimeters   Conversion:      1.00
Specify insertion point or [Basepoint/Scale/X/Y/Z/Rotate]: 0,0
Enter X scale factor, specify opposite corner, or [Corner/XYZ] <1>:
Enter Y scale factor <use X scale factor>:
Specify rotation angle <0>:
Enter attribute values
Please Enter Designer:-: ??
Please Enter Date:-: ??
Please Enter CAD Eng:-: ??
Please Enter Checker:-: ??
Please Enter Scale:-: ??
Please Enter Drawing No.:-: ??
Please Enter Rev No.:-: ??
Please Enter Status:-: ??
Command: _zoom
Command: _zoom
Specify corner of window, enter a scale factor (nX or nXP), or
[All/Center/Dynamic/Extents/Previous/Scale/Window/Object] <real time>: e
Command: _filedia
Enter new value for FILEDIA <0>: 1
AutoCad2021
Command: -insert
Enter block name or [?]: "W:/Cad Dept/CAD Data/Block Library/Title Blocks/Blank Block Files/A1 Landscape Title Block"
Specify insertion point or [Basepoint/Scale/X/Y/Z/Rotate/Explode/REpeat]: 0,0
Command: ??
Unknown command "??".  Press F1 for help.
Command: ??
Command: ??
Command: ??
Command: ??
Command: ??
Command: ??
Command: ??
Command: _zoom
Regards
Vincent
Replies (7)
Message 2 of 8
ВeekeeCZ
That is not about FILEDIA but rather about ATTREQ or ATTDIA.
Message 3 of 8
vincent
Thank you for replying, Please can you explain a bit more,
Message 4 of 8
vincent
all sorted, thank you.
Message 5 of 8
cadffm
Fine,
you found your attreq on (what you want),
But attdia on, what you don't want.
Note: Filedia is useless, Lisp will start the commandline dialog for file selection,
independed of your filedia setting.
Also Macro, Script, (send)command - all automation inside autocad.
Sebastian
Message 6 of 8
Sea-Haven
A loophole Filedia 0 when asked press ~ tilde key dialog will pop open. Handy when forget name or a typo problem.
Message 7 of 8
pbejse
Nice 👍
Message 8 of 8
Sea-Haven
One of those undocumented  ! Like support paths double dot ..
