Well, I'll take you're word for it, that it works (but i have my doubts), but it's been a long time since i've seen such overkill of if's 😁
I just couldn't resist rewriting the lot.
Some explanation should be in place, but there's just to much...
I'll advice you to take a good look at the IF & COND statements and the use of variables.
Both by comparing your code to mine and by reading up on them in a manual or tutorial.
- you REALY don't need to check a variable 3 times, for 3 different var=value
- there's no need to repeat the same code 5 times, for 1 different number
- you can't (setq ...) a sysvar, neither can you compare it just by name as regular variables. Always use setvar and getvar for those.
& are you sure the "result" variable is EVER going to be above 1?
- getstring 1"" -to- getstring 5"" ???
See why I have my doubts that it works, correctly ?
and i found another custom function, not mentioned before:
EditAttribute2
So, here's the massively reduced code, which should do exactly the same (untested, bc: no sample dwg)
(vl-load-com)
(defun c:Submittal ( / result subDate subWhy subTo tag1 tag2 tag3)
(command "-layer" "ON" "*" "")
(command "-layer"
"OFF"
"Cutlist-FULL,*|Cutlist-FULL,Cutlist-2,*|Cutlist-2,Cutlist-4,*|Cutlist-4,Cutlist-8,*|Cutlist-8,Cutlist-12,*|Cutlist-12,Cutlist-16,*|Cutlist-16,Cutlist-24,*|Cutlist-24,Cutlist-32,*|Cutlist-32,Cutlist-48,*|Cutlist-48,Cutlist-96,*|Cutlist-96"
(while (= (getvar 'users1) "")
(initget "ONE ALL")
(setvar 'users1 (getkword "\n(O)ne Tab or (A)ll? : ")))
(If (= (getvar 'users1) "ONE")(setvar 'users1 "CTAB"))
(while (not (getvar useri3))
(setvar 'useri3 (getint "\nEnter Submittal Number <1-5> : "))
(Setq Date (YMD))
(if (= (setq SubDate (getstring "\nEnter Submittal Date or Enter for Today: ")) "")(setq Subdate1 Date))
(while (not SubWhy)
(initget "Approval Resubmittal ForRecord")
(setq SubWhy (getkword "\nfor (A)pproval/(R)esubmit for approval/(F)or record: "))
(cond
((= SubWhy "Approval")
(Setq SubWhy "FOR APPROVAL" SubStatus "OUT FOR APPROVAL")
(setvar 'users4 "SUBMITTAL PENDING")
((= SubWhy "Resubmittal")
(Setq SubWhy "RESUBMIT FOR APPROVAL" SubStatus "OUT FOR APPROVAL")
(setvar 'users4 "RESUBMITTAL PENDING")
((= SubWhy "ForRecord")
(Setq SubWhy "SUBMIT FOR RECORD" SubStatus "RECORD SET")
(while (or (not subTo)(= subTo ""))
(setq SubTo (getstring T "\nSubmitted to: "))
(setq subnum (itoa (getvar 'useri3))
tag1 (strcat "SubDATE" subnum)
tag2 (strcat "SubWhy" subnum)
tag3 (strcat "SubTo" subnum)
(setq result (EditAttribute2 "Submittals" tag1 SubDate))
(setq result (EditAttribute2 "Submittals" tag2 SubWhy))
(setq result (EditAttribute2 "Submittals" tag3 SubTo))
(If (/= SubStatus "RECORD SET")
(setq result (EditAttribute2 "DrawingInformation" "Status" SubStatus))
(princ (cond ((= result 0) "Nothing changed.")
((= result 1) "Changed one attribute.")
(T (strcat "Changed "(itoa result) " attributes."))
(DWGInfo)
(setvar 'users2 JOBYEAR)
(setvar 'users3 JOBNUMBER)
(setvar 'users4 SERIES)
(command "-vbarun" "exportattribsSubmittals" "")
(princ)
