Selecting blocks by name
Dear Experts,
I have lisp code that can select the blocks entire drawing, But instead of that I need to select particular WINDOW area. Requesting to change the code as per requirement
(vl-load-com)
(defun c:SBN ( / bn ss i sn)
  (if (and (setq bn (getstring "Block name: "))
	   (setq ss (ssget "_X" (list '(0 . "INSERT")
				      (cons 2 (strcat "`*U*," bn))))))
    (repeat (setq i (sslength ss))
      (if (not (wcmatch (vla-get-effectivename (vlax-ename->vla-object (setq sn (ssname ss (setq i (1- i)))))) bn))
	(ssdel sn ss))))
  (if ss (sssetfirst nil ss))
  (princ)
Thanks & Regards,
T.Brahmanandam
rkmcswain
Your (ssget) function is using the "_X" selection method, which is "entire database".
Sounds like you want to use the "_W" selection method.
Example:
(ssget "_W" '(0 0) '(5 5))
See more here: http://help.autodesk.com/view/ACD/2021/ENU/?guid=GUID-0F37CC5E-1559-4011-B8CF-A3BA0973B2C3
R.K. McSwain     | CADpanacea | on twitter
Sir, myself tried with that code also, but not able to perform the operation, Can you please edit the code as per my requirement?
Kent1Cooper
@Anonymous wrote:
... Can you please edit the code as per my requirement?
Not without knowing what your "particular WINDOW are" is.
Kent Cooper, AIA
Sorry Sir,
It's my mistake, while wiritng.
It is not "Particular Window", It's only "User Window Selection"
Kent1Cooper
Then just remove the "_X", and it will find qualifying things among the User selection [whether by Window or otherwise], rather than in the entire drawing.
Kent Cooper, AIA
Working nicely Sir.
I got the solution , Feeling happy.
