Variable or command Number of recently used
carlos_m_gil_p
Message 1 of 9
carlos_m_gil_p
Hello boys how are you.
Could someone tell me with which variable or command I can modify the Number of recently-used files in Application Menu.
Thank you.
AutoCAD 2026
Visual Studio Code 1.99.3
AutoCAD AutoLISP Extension 1.6.3
Windows 10 (64 bits)
Replies (8)
Message 2 of 9
john.uhden
Looks like you got it.  I think 9 is the maximum.
John F. Uhden
Message 3 of 9
carlos_m_gil_p
Hi @john.uhden the maximum is 50.
What I want is a variable or command to modify it from LISP
AutoCAD 2026
Message 4 of 9
CodeDing
@carlos_m_gil_p ,
I have been trying to find a variable to control this for the last ~30 minutes.
I can not find anything that relates or will adjust it.
I can tell you that the variable you are NOT looking for is the "MRUFilesToList" Environment Variable (it changes the option above the one you have highlighted).
Best of luck searching.
Best,
~DD
Message 5 of 9
dlanorh
I don't think you can modify it from lisp. The recent Files list is stored in the registry, and despite this number, there will eventually be fifty files (the max) stored in the registry. If you want a list of these files see THIS
I am not one of the robots you're looking for
Message 6 of 9
carlos_m_gil_p
Hi @CodeDing
Yes, I already tried that variable and it didn't work.
AutoCAD 2026
Message 7 of 9
carlos_m_gil_p
Hi @dlanorh
I don't want a list of these files.
I just want to modify the amount that is going to show.
Put a specific value between 1 and 50.
AutoCAD 2026
Message 8 of 9
dlanorh
As I mentioned in my previous post, I don't think this is possible using lisp. You can access the number via preferences-opensave-mrunumber property, but this is listed as read only.
It's not stored in the registry, and it's not saved as a system variable. It may be possible using arx or .NET, but not lisp.
Message 9 of 9
carlos_m_gil_p
Perfect, thanks for the information.
AutoCAD 2026
