How to fillet two plines?
I'm writing a function that I just have to enter the dimensions to get a drawing.
Here is the 'plines' code:
(command "pline" p7 p2 p1 p3 p4 "") ;line1
(command "pline" p4 p9 "") ;line2
(command "pline" p10 p11 "") ;line3
After running the function, I get the following drawing:
The intersected lines are 'line2' and 'line3' from the code.
I wanna write a code that can fillet those two lines with radius 0 like this:
How do I manage to make it?
Best regards.
Since you have the pts already, why not use INTERS function to calc the intersection and just continue drawing the pline.
@Anonymous, thank you so much!
I didn't know about this function (newbie), and it worked pretty well.
Regards!
Sea-Haven
Look into the vl function intersectwith also it has far more functionality looking at objects rather than points.
(setq intpt1 (vlax-invoke obj2 'intersectWith obj1 acExtendThisEntity))
