Variable list for options settings
Nathan_Tigner
Nathan_Tigner
Hello All,
I am writing a lisp to change many of the paths in options>files
I have figured out the search paths, printer support file path, and template settings.
What I'm actually wondering is, where can I find a list of all the variables use in the options dialog?
For instance, I can set the Printer Support File Paths using "PrinterStyleSheetDir" and I can change the default template file name for qnew with "QnewTemplate".
I was looking for a list of all those variables to make life easier but I can't seem to find them.
I can even find any documentation on the "QnewTemplate" variable, I just happened to stumble accross it in another post.
Any info would be greatly appreciated.
Sea-Haven
Have a look at this its an old version I now check does path exist if not add, also do a menuload.
; resets the paths usefull for update versions of Autocad
; by Alanh 2011
; This sets a reference to the install path of your product
; the gets are their for info maybe other use
; use this to find other settings
;(vlax-dump-object (vla-get-files (vla-get-preferences (vlax-get-Acad-object))) T)
(vl-load-com)
(defun setpaths ( / *files* doc)
; make temp directory
(if (vl-file-directory-p "C:\\Acadtemp\\")
(Princ "Acadtemp exists")
(vl-mkdir "C:\\AcadTEMP\\")
(setq *files*  (vla-get-files  (vla-get-preferences (vlax-get-Acad-object))))
; savepath
;(vla-get-AutoSavepath *files*)
(vla-put-AutoSavepath *files* "C:\\AcadTemp")
; custom icons
;(vla-get-CustomIconPath *files*))
(vla-put-CustomIconPath *files* "L:\\Autodesk\\ICONS")
; custom menu
;(vla-get-Menufile *files*))
;(vla-put-Menufile  *files* "C:\\Users\\2013xxx")
; printers config
;(vla-get-PrinterConfigPath *files*)
(vla-put-PrinterConfigPath *files* "L:\\AutoDESK\\Plotting\\Plot Styles 2011")
; printers style sheet
;(vla-get-PrinterStyleSheetPath *files*)
(vla-put-PrinterStyleSheetPath *files* "L:\\AutoDESK\\Plotting\\Plot Styles")
; printer drv's
;(vla-get-PrinterDescPath *files*)
(vla-put-PrinterDescPath *files* "L:\\AutoDESK\\Plotting\\Drv")
; print spooler
;(vla-get-PrintSpoolerPath *files*)
(vla-put-PrintSpoolerPath *files* "C:\\AcadTemp\\")
; template  path
;(vla-get-TemplateDwgPath *files*)
(vla-put-TemplateDwgPath *files* "L:\\Autodesk\\c3d Templates")
; template location
;(vla-get-QnewTemplateFile *files*)
(vla-put-QnewTemplateFile *files* "L:\\Autodesk\\c3d Templates\\xxxx-2019.dwt")
;make new support paths exist + new
(setq paths (vla-get-SupportPath *files*))
(setq XXXXpaths "L:\\autodesk\\supportfiles;L:\\autodesk\\lisp;L:\\autodesk\\fonts;")
(setq newpath (strcat XXXXpaths paths))
(vla-put-SupportPath *files* newpath)
; Tempdirectory
;(vla-get-TempFilePath *files*))
(vla-put-TempFilePath *files* "C:\\AcadTemp\\")
;   PlotLogFilePath = "C:\\Documents and Settings\\YYYY.XXXX-AD\\localsettings\\application data\\autodesk\\c3d 2011\\enu\\"
(vla-put-PlotLogFilePath *files* "C:\\AcadTemp\\")
;   LogFilePath = "C:\\Documents and Settings\\YYYY.XXXX-AD\\localsettings\\application data\\autodesk\\c3d 2011\\enu\\"
(vla-put-LogFilePath *files* "C:\\AcadTemp\\")
; xref temp path
;(vla-get-TempXrefPath *files*))
(vla-put-TempXrefPath *files* "C:\\AcadTemp\\")
; end use of *files*
(setq oldtrust (getvar 'trustedpaths))
(setq newtrust (strcat oldtrust ";" "L:\\Autodesk..."))
(setvar 'trustedpaths newtrust)
(princ "All Done")
) ; defun
(setpaths)
(alert "Run user script for toolbars")
; exit quitely
