LISP to automatically offset/extend all green lines 96 which do not intesect
adelin_farcas
adelin_farcas
Hello AutoCAD Gurus!
I'mm raising thiis concer/idea and I'm terribly sorry if it was posted before. I searached for it but no luck.
We're testing in AutoCAD a solution to take items to a waterject machine, and by 3rd party intergrations, some drawing may be poor. In out case the notches (green) will not touch the silhouette and this mayu be problematic. Usually we would ask the user to EXTEND manually, but in case of hunders of silhouettes this is tough, and not very observable.
Are there any LISP script which would automaticaaly select all the green plines (which may not intersect already) and Extend/Move/Offset them so that it "connects" with the Silhouette?
I'm adding a DWG, maybe it helps any expert around. Thank you, thank you!
adelin_farcas
This issue is like the https://forums.autodesk.com/t5/visual-lisp-autolisp-and-general/easiest-way-to-extend-join-the-line-... issue which i've identified, but with no resolution.
