Variable for viewport will not recognize as a viewport
Gorra
Message 1 of 13
Gorra
I am having trouble making an loop for user-selecting a viewport as a variable, and test to make sure it is a viewport before proceeding to the next one. I've had the problem before but the usual tweaks aren't working. Whether I use ssget and then ssname, or if I use entsel and then car, I'm still getting the target as an ename and not a viewport. If I convert to a vla it becomes a vla object and some methods can be applied, but its object type is a vla-object and not a viewport. I am using the (0 . "VIEWPORT") filter on ssget, but this doesn't give an error on selection to re-select, it just chokes on the resulting nil value farther down the lisp.
(alert "\nSelect viewports one at a time from top to bottom")
(setq VwPrt1 (ssget "_+.:E:S" '((0 . "VIEWPORT"))))
(setq VP1v (vlax-ename->vla-object (ssname VwPrt1 0)))
(while (/= (type VP1v) "VIEWPORT")
  (progn
    (princ "Object must be a viewport")
Thanks for any help
Gorra
Replies (12)
Message 2 of 13
paullimapa
perhaps the problem occurs when an object is selected as the vport?
share a sample dwg with the vports you're trying to select.
Paul Li
IT Specialist
@The Office
Message 3 of 13
paullimapa
@Gorra updated
FYI: this line of code is incorrect:
Should be:
(/= (vla-get-objectname VP1v) "AcDbViewport")
Paul Li
IT Specialist
@The Office
Message 4 of 13
Gorra
@paullimapa Thanks for the reply. That's probably the problem but testing it isn't going smoothly. I will try to extract what I'm allowed to post online but that will take a bit.
Gorra
Message 5 of 13
Sea-Haven
Checking you have chosen a viewport, tone is an abrupt exit which is not really a clean way, you can use a (progn instead and wrap all the following code in it, oh yeah a while.
(if (setq VwPrt1 (ssget "_+.:E:S" '((0 . "VIEWPORT"))))
(progn (alert "You did not pick a viewport /n/nThe program will now Exit please run again")
(EXIT)
(progn
...... all your code
) ; progn
) ; if
(while (/= VwPrt1 nil)
(setq ok "Yes")
(setq vwprt1 nil)
) ; while
(if (= ok "Yes")
  (princ)
Message 6 of 13
komondormrex
hey,
following your algorithm logic
(while (not (setq VwPrt1 (ssget "_+.:E:S" '((0 . "VIEWPORT")))))
    (princ "\rObject must be a viewport")
Message 7 of 13
Gorra
@komondormrex @Sea-Haven @paullimapa
Tried all three solutions with no change: the selection accepts any object and moves along to the next selection (without setting it to nil). Do I have an error in my ssget strings?
I can't think of any other reason it should be ignoring its restrictions. The sub function is this:
(defun GetLayout (CLName / VP1v VP2v VP3v)
  (if (< LytCnt 2) ;; If only 1 layout
    (progn
      (command-s "-layout" "D" "PL002") ;; delete sheet PL002
      (command-s "-layout" "S" "PL001")
      (GetViewports)
    (progn
      (setq VwPrt1 nil) ;; Clearing any residual values
      (setq VwPrt2 nil)
      (setq VwPrt3 nil)
      (setq VP1v nil)
      (setq VP2v nil)
      (setq VP3v nil)
      (if (eq CLName "PL001")    ;; if more than one sheet and this is PL001 being processed
        (progn
            (princ "\nObject must be a viewport")
          (vla-put-center VP1v (vlax-3D-point '(8.5 8.866396 0.0)))
          (alert "top vp placed")
          (while (not (setq VwPrt2 (ssget "_+.:E:S" '((0 . "VIEWPORT")))))
            (princ "\nSecond target must be a viewport")
          (setq VP2v (vlax-ename->vla-object (ssname VwPrt2 0)))
          (vla-put-center VP2v (vlax-3D-point '(8.5 6.316396 0.0)))
          (alert "\nsecond vport placed")
          (while (not (setq VwPrt3 (ssget "_+.:E:S" '((0 . "VIEWPORT")))))
            (princ "\nBottom target must be a viewport")
          (setq VP3v (vlax-ename->vla-object (ssname VwPrt3 0)))
          (vla-put-center VP3v (vlax-3D-point '(8.5 3.766396 0.0)))
          (alert "bottom vport placed")
          (setq VPCnt 3)
        ) ;;end PL001 true progn
        (progn
          (setq CrrntTb (+ TrLyt CrrntLyt))
          (CreateLayout CLName)
          (GetViewports)
        ) ;; end PL001 false progn
      )  ;; end if PL001
  )  ;; end single layout false
 )  ;; end if single layout
(alert "viewports positioned")
) end GetLayout
VwPrt1/2/3 are global variables.
Gorra
Message 8 of 13
paullimapa
could you share an example dwg?
Paul Li
IT Specialist
@The Office
Message 9 of 13
Gorra
Attached is a sample dwg and the rest of the code. The rest of the code has other issues but the task in question is the first interaction it does with the user.
Message 10 of 13
paullimapa
Here's the tst.lsp code I'm using just on the first vport of your sample dwg:
(defun c:tst (/ vwprt1 vp1v)
 (setq vwprt1 nil vp1v nil)
 (if vwprt1
  (progn
;   (vlax-dump-object VP1v)
  (alert"not a valid object")
 (princ)
I purposely moved the vports including the pline away before running tst.lsp
Here's a screenshot of the vports before:
After loading tst.lsp, I then enter at the command prompt tst and selected the top vport.
The AutoCAD message box would appear notifying "top vp placed" and after clicking ok here's the screenshot afterwards:
The vport moved as programmed.  Is this not what's happening for you?
Try my sample tst.lsp and see if at least this portion of the code works for you.
Paul Li
IT Specialist
@The Office
Message 11 of 13
Gorra
@paullimapa
It does indeed work in the stripped-down version dwg I posted, but not in the working drawing I was using. Looks like there's some layout name mis-matches that are making it fail rather than the code. Thanks for all the effort!
Gorra
Message 12 of 13
paullimapa
you're welcome...cheers!!!
Paul Li
IT Specialist
@The Office
Message 13 of 13
Sea-Haven
I may have an answer for you a completely different way of approaching this problem i have a couple of make viewport programs, in particular walk along a pline making rectangs that represent Viewports, part two of the code select all rectangs and new layouts are made with matching viewports. They include adding a twist as in your sample dwg you have not followed the shape where it bends what I have does that.
Look at the images and have a look at the movie. Rectangs can be added, rotated, moved or even deleted before making layouts. Pretty sure was asked before for a multi viewport answer. I don't think I finished but is possible to do,
Let me know if interested.
