using tabs in a macro
gbG5A5W
Message 1 of 14
gbG5A5W
I'm trying to create a text, using a button with a macro in the toolpalette. The text-part works:
_.-Mtext \h;2;w;200;Mytext;;
Now I want to use tabs between the text:
Mytext -TAB- Mytext -TAB- Mytext
Using the tab-button in the Tool properties the cursor jumps to the next line. AutoCAD suggests ^I, but that creates 3 spaces instead of a tab. Using the columns-option is difficult, because the number of lines is not always the same. How do I get this working?
Replies (13)
Message 2 of 14
ВeekeeCZ
I've tried... don't see any issues.
Use LIST command to export the MTEXT content to the commandline then copy-paste the exported text with tabs included to the tool definition.
_.-Mtext \h;2;w;200;Mytext MyText;;  (where space is a tab)
Message 3 of 14
Kent1Cooper
@gbG5A5W wrote:
.... I want to use tabs between the text:
You can see by looking at the entity data that a Tab is represented by "\t" in Mext.  Use something like this for the content:
(strcat "MytextA" "\t" "MytextB" "\t" "MytextC")
Those "Mytext..." parts can be variables containing Text string content if you need it that way.
They must be lower-case t's -- "\T" will not work.
Kent Cooper, AIA
Message 4 of 14
gbG5A5W
Tried this. There's no tabs, but spaces instead
Message 5 of 14
gbG5A5W
The "strcat" suggests you are using it in a LISP, right? I'd rather use it in a macro
Message 6 of 14
gbG5A5W
In addition: the text after the list-command has also spaces instead of tabs already
Message 7 of 14
Kent1Cooper
Many AutoLisp functions will work in macros [I haven't tested this one, but try it].
Kent Cooper, AIA
Message 8 of 14
Kent1Cooper
@gbG5A5W wrote:
.... the list-command has also spaces instead of tabs ....
For the "whole story," use this on an Mtext object containing tabs:
(cdr (assoc 1 (entget (car (entsel "\nSelect Mtext to see its content: ")))))
It's in entity data that you see how it "really" stores the information.
You can also see the tabs in the "TextString" property of the Mtext converted to a VLA object:
(vla-get-TextString (vlax-ename->vla-object (car (entsel))))
Kent Cooper, AIA
Message 9 of 14
Sea-Haven
This was a simple test of a's then space b's then  tab and 'c's in a mtext. The entget returns as suggested by Kent. (1 . "aaaa bbb\tccc")
There is no problem using lisp in pop or toolbar menu's, (strcat "MytextA" "\t" "MytextB" "\t" "MytextC") simple to test in your tool palette.
(command "Mtext" pause pause (strcat "MytextA" "\t" "MytextB" "\t" "MytextC") "")
Message 10 of 14
gbG5A5W
Using LISP-code in a macro is new to me, I'll give it a try. Thnx everyone for the help.
Message 11 of 14
komondormrex
@Sea-Haven wrote:
There is no problem using lisp in pop or toolbar menu's...
have you tried it as ts wants it to?
Message 12 of 14
gbG5A5W
Ans is it just the case of copying
in the command string of the tool palette properties? In that case I can't seem to get it to work.
Message 13 of 14
ВeekeeCZ
_.-Mtext \h;2;w;200;-;;(setpropertyvalue (entlast) "Contents" (strcat "MytextA" (chr 9) "MytextB" (chr 9) "MytextC"))(princ)
Message 14 of 14
gbG5A5W
Thnx, that works
