Express tool does not work using AutoLISP
Lucio_Faria6VXA6
Lucio_Faria6VXA6
Community Visitor
Community Visitor
Dear all.
I'm trying to use the BURST command in the AutoLISP but it says that the command is unknown. But I have the Express tools installed and I can use this command in AutoCAD. I have reinstalled and fixed the software, but still gets the same error message.
This is my AutoLISP code:
(defun c:BurstAll (/ ss ent obj)
(vl-load-com) ; Load Visual LISP functions
(setq ss (ssget "X" '((0 . "INSERT")))) ; Select all block references in the drawing
(if ss
(progn
(setq i 0)
(repeat (sslength ss)
(setq ent (ssname ss i)) ; Get entity name
(setq obj (vlax-ename->vla-object ent)) ; Convert entity name to VLA-object
; Check if the block has attributes (Burst only works on blocks with attributes)
; If you want to burst all blocks, even without attributes, you'd modify this.
; However, Burst's primary purpose is to explode blocks while retaining attribute values.
(if (vlax-property-available-p obj 'HasAttributes)
(progn
(if (eq :vlax-true (vla-get-hasattributes obj))
(progn
(command "BURST" ent "") ; Execute the Burst command on the block
(princ (strcat "\nBursting block: " (vla-get-effectivename obj))) ; Print block name to command line
(princ (strcat "\nSkipping block (no attributes): " (vla-get-effectivename obj)))
(princ (strcat "\nSkipping block (not an attribute block): " (vla-get-effectivename obj)))
(setq i (1+ i))
(princ "\nFinished bursting all eligible blocks.")
(princ "\nNo blocks found in the drawing.")
(princ) ; Suppress nil return
Moshe-A
@Lucio_Faria6VXA6  hi,
That is absolutely true, (command) function can only run build-in\standard AutoCAD commands and BURST is AutoLISP command from ExpressTools
You can call though from your program as (c:burst)
Moshe
-didier-
Bonjour @Lucio_Faria6VXA6
You must verify that express are loaded.
If you are not sure, type this line at the beginning of your program.
(acet-load-expresstools)
After you can use the command like that (c:burst)
Amicalement
Éternel débutant.. my site for learning : Programmer dans AutoCAD
DA
DGCSCAD
To sum up all of the above in a LISP:
(defun c:burstall ( / ss)
(if (= (or (member "acetutil.arx" (arx)) (and (findfile "acetutil.arx") (arxload "acetutil.arx" nil))) T);check for acet
	(progn
		(setq ss (ssget "_X" '((0 . "INSERT")))) ;get all blocks
		(sssetfirst nil ss) ;highlight selection set ss
		(c:burst) ;apply the burst
	(princ "\nNo Express Tools installed.")
AutoCad 2018 (full)
Win 11 Pro
chan230984
(defun c:BurstAll (/ ss ent obj attribs i)
(vl-load-com)
(princ "\nStarting to burst all eligible blocks...")
(if ss
(progn
(setq i 0)
; Add error handling for each block
(if (vl-catch-all-error-p
(vl-catch-all-apply
'(lambda ()
(if (and (vlax-property-available-p obj 'HasAttributes)
(eq :vlax-true (vla-get-hasattributes obj)))
(progn
; Get a list of attributes
(setq attribs (vlax-safearray->list (vlax-variant-value (vla-getattributes obj))))
; Loop through each attribute
(foreach attrib attribs
; Get attribute properties
(setq text_string (vla-get-textstring attrib))
(setq insert_point (vlax-safearray->list (vlax-variant-value (vla-get-InsertionPoint attrib))))
(setq height (vla-get-height attrib))
(setq rotation (vla-get-rotation attrib))
; Add text at the same position and with the same properties as the attribute
(vla-addtext (vla-get-modelspace (vla-get-activedocument (vlax-get-acad-object))) text_string (vlax-3d-point insert_point) height)
(vla-put-rotation (vlax-get-acad-object) rotation)
; Delete the old attribute
(vla-delete attrib)
; Explode the block
(command "EXPLODE" ent "")
(princ (strcat "\nSuccessfully burst block: " (vla-get-effectivename obj)))
(princ (strcat "\nSkipping block due to error: " (vla-get-effectivename obj)))
(setq i (1+ i))
(princ)
