Using -publish and dsd files
Message 1 of 10
Hello all,
I am trying to write a autolisp script to publish pdfs from a dsd file. When we load the dsd file with the PUBLISH command, publishing works just fine.
However, if I use -PUBLISH and load the same dsd file, it won't work and has the ERROR: device not found.
Any tips?
Replies (9)
Message 2 of 10
CodeDing
@Anonymous ,
What path are you putting into the "-PUBLISH" command to locate the dsd file?
Ex:
- "//..file.dsd"
- "c:\\me\\desktop\\file.dsd"
EDIT:
Also, Try this troubleshooting guide first:
https://knowledge.autodesk.com/support/autocad/troubleshooting/caas/sfdcarticles/sfdcarticles/device-not-found-when-publishing-in-autocad.html
Message 3 of 10
Sea-Haven
Are you just trying to plot multiple layouts of a single drawing ? I have lisp for plot a range of layouts to pdf with option of join into single pdf. Just post if you want it.
Message 4 of 10
maratovich
Which ERROR do you get?
Give a picture of the error.
Software development
Automatic creation layouts and viewport. Batch printing drawings from model.
www.kdmsoft.net
Message 5 of 10
@CodeDing wrote:
@Anonymous ,
Ex:
- "//..file.dsd"
EDIT:
This is the line as I have it:
(setvar "filedia" 0)
(command "-publish" "F:\\941-001Apartment\\Dwg\\M200.dsd")
The dsd file has multiple layouts from multiple drawings unfortunately.
The command line output looks like this:
Command: DSDPUBLISH
-publish Enter name of sheet list <>: F:\941-001Apartment\Dwg\M200.dsd
'C:\Users\rleuba\Documents\M200.pdf': Errors found
 And the Plot and Publish Details Window Shows:
 Job: - Error(s) Did Not Plot
Job ID: 2
Sheet set name:
Date and time started: 7/1/2020 9:04:01 AM
Date and time completed: 7/1/2020 9:04:01 AM
UserID: rleuba
Profile ID: 2014Base
Total sheets: 1
Sheets plotted: 0
Number of errors: 1
Number of warnings: 0
 Sheet: M200-M201 - Error(s) Did Not Plot
File: F:\941-001Apartment\Dwg\M200.dwg
Category name:
Page setup:
Device name:
Plot file path:
Paper size:
ERROR: Device not found
Message 6 of 10
Sea-Haven
Have thought about changing the code to not ask for range but rather run from say Aeccoreconsole.
DWG1 (load "plotpdf")(plotpdf 1 56)
dwg2  (load "plotpdf")(plotpdf 1 100) ;  1000 means all sheets
dwg3  (load "plotpdf")(plotpdf 3 5)
Message 7 of 10
maratovich
Job ID: 2
Sheet set name:
UserID: rleuba
Total sheets: 1
Sheets plotted: 0
Number of errors: 1
Category name:
Page setup:
Device name:
Plot file path:
Paper size:
Your drawings do not have print settings.
In the drawing, the printer, sheet format and the rest should be selected.
Have you ever printed from your drawing?
www.kdmsoft.net
Message 8 of 10
Thanks for the input folks. I figured out a way to make it work. When creating the dsd file in the "publish" window, you need to have have the "Publish to:" option set up as plotter named in page setup. It won't work if you use the DWG to PDF override.
Unfortunately, most of the drawings in my company do not have the plotter set up properly in each drawing. Does anyone know of a way to use the DWG to PDF override with the -publish command?
Message 9 of 10
maratovich
Add an example of your file.
www.kdmsoft.net
Message 10 of 10
gjvriend
Hello
Filedia shoot be on zero (0)
