Change attribute datatype for use in table formulae (AutoCAD LT 2019)
NOTE: Using AutoCAD LT 2019; don't have experience using Macros in AutoCAD
Aim:
to count/sum quantities of items (blocks) - plan to use sum/count table formulae for fields referencing these quantities
Approach:
defined attribute called 'BlkQty' for each block and defined count in them (AS NUMBERS, ex: 2, 5, etc.)
Inserted fields in a table referencing this 'BlkQty' attribute of various blocks in individual cells of a column. When I tried to use the sum or count table formula, the result still shows zero.
Problem:
I think I am not getting the intended result of total block quantities because block attributes are viewed as text (? - I wasn't able to verify this anywhere though). I tried inserting plain numbers in another column of the same table and to my surprise I was able to use count/sum for those cells. Hence, I reached the conclusion that attributes might be viewed as text.
Is there any way I can defined a number in an attribute of a block and use the sum table formula on fields that reference these attributes?
CodeDing
@Anonymous ,
If you are trying to place Attribute values into cells in a table as fields, then SUM those cells, you can do it this way...
For your blocks, create formulas of the Field Count * 1. Like this:
Then you can use the SUM formula as expected:
Final product:
Hope that helps!
Best,
~DD
Thank you @CodeDing  - it seems silly to have asked this question now. I should have thought of this.
This simple fix works as intended!
CodeDing
@Anonymous ,
Glad to help.
For your reference, all my method accomplishes is changing the Cell Data Type from "Text" to a "Whole Number".
If you can find a way to keep the cell in a "Whole Number" data type with only the field in it, then you will NOT need to use the formula (=x*1).
Bad for your use:
Good for your use:
Also, welcome to the forums! Come back whenever you need help.
Best,
~DD
lena.talkhina
Welcome to the Autodesk Community @Anonymous !
Great  see you on LISP forum and that you already received the solution!  Thanks @CodeDing  for helping our new community members.
Check this link if you have any question about forums.
Находите сообщения полезными? Поставьте "НРАВИТСЯ" этим сообщениям! | Do you find the posts helpful? "LIKE" these posts!
На ваш вопрос успешно ответили? Нажмите кнопку "УТВЕРДИТЬ РЕШЕНИЕ" | Have your question been answered successfully? Click "ACCEPT SOLUTION" button.
Лена Талхина/Lena Talkhina
Менеджер Сообщества - Русский/Community Manager - Russian
