Using AutoLISP to one-way transfer a field value to a plain-text attribute
matthew_neesley
matthew_neesley
Hello to all:
I've created a nice conundrum for myself.  My company is building an add-on for AutoCAD that uses hundreds of simple blocks that I've made, all stored in Vault.  I've added an attribute in these blocks that use the VaultRevision field, so every time I check the block out and modify it, I can update that attribute automatically.
The problem is...all of these blocks eventurally get copied into a different master-file that the add-on draws from.  This copying removes the dynamic field capability from the attribute, and in the destination file, the attribute merely displays ###.
The only thing I can think of...is to have a way to one-way transfer the text value from the field to a different attribute that is has nothing dynamic about it.  Is this possible?  I've attached a pic that shows what I'm trying to accomplish, and the file with the block.  Thanks in advance for any help!
paullimapa
To start you off here is how I would get the value of that attribute:
(getpropertyvalue (car (entsel)) "ASCEND_REVISION")
Paul Li
IT Specialist
@The Office
