Accessing Sub Model/ Model Browser and Radiation Calcs in AutoLISP
kagan_p_giltinan
Observer Observer
Message 1 of 9
kagan_p_giltinan
Observer
Observer
Hi everyone,
I am very new to AutoLISP and have been wanting to somehow access certain nodes in a sub model of my model browser and change the radiation setting of the nodes. For example, a node is named "LV_.2" in a "LV" sub model.
Though I run into an issue with a ssget or entget call in my .lsp file. As when I do that for any given object, I don't see the name "LV_.2" in the entities data. I wanted to ask if there's any way to access the sub model in the model browser and correlate the name, "LV_.2", to the actual entity's internal fields such as entity name or entity handle. As I then want to make changes to the entity's radiation setting in my thermal desktop tab.
Note: I have a list of nodes that I need to change that are only labelled via the "LV_.#" naming convention.
Replies (8)
Message 2 of 9
paullimapa
share a dwg with one of these sub models
Paul Li
IT Specialist
@The Office
Message 3 of 9
kagan_p_giltinan
Observer
Observer
I am not allowed to share the file
Message 4 of 9
paullimapa
you don't have to share the exact file...make something up that shows this kind of setup inside the dwg so community has an idea of what it looks like
Paul Li
IT Specialist
@The Office
Message 5 of 9
kagan_p_giltinan
Observer
Observer
This is a screenshot of an example. I only made one surface to illustrate the model tree. Though I have multiple surfaces all under "LV_" and then a list of nodes which I want to edit radiation properties for a given surface corresponding to a node number in that list
Message 6 of 9
paullimapa
Are you running something other than vanilla AutoCAD?
Paul Li
IT Specialist
@The Office
Message 7 of 9
kagan_p_giltinan
Observer
Observer
I am using thermal desktop add-on, otherwise vanilla AutoCAD
Message 8 of 9
paullimapa
Does thermal desktop add-on give you this window?
I also don't know what is a Submodel Node Tree
Paul Li
IT Specialist
@The Office
Message 9 of 9
Sea-Haven
Have you contacted the authors of this software, getting inside custom software can be a nightmare, NEED A DWG.
