Problem:
- We're attempting to automate title block updates in AutoCAD drawings using Lisp, by extracting attribute data from an Excel spreadsheet.
- The Lisp code successfully creates an Excel Application COM object using (vlax-get-or-create-object "Excel.Application").
- However, the code consistently fails when attempting to open an Excel workbook using (vlax-invoke excelApp 'Workbooks 'Open formattedFilePath), resulting in a "Member not found" error.
Troubleshooting Steps Taken:
- Verified Excel file path and file existence.
- Tested with simple, empty Excel files.
- Tested on multiple computers on the same network, with the same result.
- Verified that AutoCAD and Excel are both 64-bit.
- Ran AutoCAD as administrator.
- Repaired and reinstalled Microsoft 365.
- Tested general COM object creation with (vlax-get-or-create-object "Scripting.FileSystemObject") which succeeded.
- Tested excel COM object creation outside of the main function, which succeeded.
- Added a delay to the code, to rule out timing issues.
- Temporarily disabled excel protected view.
- We have not found any relevant excel related entries in DCOMCNFG.
- We have not found any relevant excel related entries in the windows registry.
Key Observations:
- AutoCAD can create general COM objects.
- AutoCAD can create excel COM objects in a simple test function.
- The failure is isolated to the (vlax-invoke excelApp 'Workbooks 'Open formattedFilePath) line.
- The problem persists across different computers on the same network.
- We are using Microsoft 365.
Request for Assistance:
- We are seeking assistance in identifying potential causes for this persistent "Member not found" error.
- We are particularly interested in any AutoCAD-specific settings, configurations, or security restrictions that might be affecting COM object interactions with Excel.
- We are also interested in any obscure excel settings, or windows settings that could be causing the issue.
- We are looking for any known compatibility issues between autocad, and microsoft 365.
Additional Information:
- We are working in a corporate network environment.
- We are working with our IT department.
The code in question is currently sitting like this:
(defun c:TestExcelOpen (/ excelApp workbook formattedFilePath excelFile)
(vl-load-com)
(setq excelFile (getfiled "Select Excel File" "" "xls;xlsx" 8))
(if (not excelFile) (progn (princ "\nNo file selected. Exiting.") (exit)))
(setq excelApp (vlax-get-or-create-object "Excel.Application"))
(if (not excelApp)
(progn
(princ "\nERROR: Could not start Excel Application.")
(exit)
(princ "\nExcel App Created. Delaying for 1 second...")
(command "_DELAY" 1000) ; Delay for 1 second
(setq formattedFilePath (vl-string-translate "\\" "/" (strcat "\"" excelFile "\"")))
(princ (strcat "\nFormatted Excel File Path: " formattedFilePath))
(setq workbook (vlax-invoke excelApp 'Workbooks 'Open formattedFilePath))
(if (not workbook)
(princ "\nError opening workbook")
(vlax-release-object excelApp)
(princ)
Full lisp routine for final goal attached.
