Python connexion with AutoCad
adrien_lambertZVQMG
Observer Observer
adrien_lambertZVQMG
Observer
Observer
Dear,
I would like to try python automation with AutoCAD so I downloaded the trial version of AutoCad which is named : Autodesk AutoCAD 2026 - UNREGISTERED VERSION.
However, I cannot connect python with autocad. I get the following error message : OSError: [WinError -2147221005] running the code bellow.
Could you please tell me if python automation is supported with this version of AutoCAD ?
NB : I don't have admin rights on my laptop, I ran python file with both vscode and cmd
Kind regards,
Adrien
Code :
import pyautocad
acad = pyautocad.Autocad()
print(acad.doc.Name)
Moshe-A
@adrien_lambertZVQMG  hi,
maybe you'll get answers >> here <<
Moshe
adrien_lambertZVQMG
Observer
Observer
Thanks for your answer.
By navigating on this website I've found the name of Autocad I should use.
To find it, you must do the following steps :
1)  Press Win + R, type regedit, and hit Enter.
2) Navigate to HKEY_CLASSES_ROOT\AutoCAD.Application
3) Look for a name associated with AutoCAD Application Object in my case it is "AutoCAD.Application.25.1
4) Try the following code, AutoCAD should open now
name_acad = "Autocad.Application.25.1"
try:
    acad = GetActiveObject(name_acad)
    print("AutoCAD is Active")
except(OSError, COMError😞 #If AutoCAD isn't running, run it
    acad = CreateObject(name_acad,dynamic=True)
    print("AutoCAD is successfuly Opened")
Kind regards,
Adrien
