LISP - draw line between selected linear and aligned dimensions
cool.stuff
Message 1 of 9
cool.stuff
Hello 🙂
I would like to ask for help.
I have a lot of disassociated linear and aligned dimensions and I need to draw a line between each dimensions' points.
I have searched in forum and net and I have found nothing.
Is this possible?
Can someone give a hand please?
Accepted solutions (4)
Replies (8)
Message 2 of 9
Kent1Cooper
If by "points" you mean the two definition points that the Dimension measures between, try this [in simplest terms, minimally tested]:
(defun C:LDDP ; = Lines between Dimension Definition-Points
  (/ ss n dim ddata)
  (if (setq ss (ssget '((0 . "DIMENSION"))))
    (repeat (setq n (sslength ss))
      (setq
        dim (ssname ss (setq n (1- n)))
        ddata (entget dim)
      ); setq
      (if (= (logand (cdr (assoc 70 ddata)) 6) 0)
        ;; linear/rotated/aligned, NOT angular/radius/diameter/ordinate
        ;; i.e. 70-code value does not contain either 2 or 4 bit
        (command "_.line" ; then
          "_non" (cdr (assoc 13 ddata))
          "_non" (cdr (assoc 14 ddata))
        ); command
      ); if
    ); repeat
  ); if
  (prin1)
It draws the Lines on the current Layer and with all current Property settings, but of course could be expanded to be more particular.  And it could use some other things, like Undo begin/end wrapping.
Kent Cooper, AIA
Message 3 of 9
komondormrex
hey,
in most simplest terms
(defun c:dim_line (/ dim_sset dimension_dxf)
  (if (setq dim_sset (ssget '((0 . "dimension"))))
    (foreach dimension (vl-remove-if 'listp (mapcar 'cadr (ssnamex dim_sset)))
      (setq dimension_dxf (entget dimension))
      (entmakex (list '(0 . "line") (assoc 8 dimension_dxf) (cons 10 (cdr (assoc 13 dimension_dxf))) (cons 11 (cdr (assoc 14 dimension_dxf)))))
  (princ)
Message 4 of 9
Kent1Cooper
That works fine for linear/aligned/rotated Dimensions, and it seems to do nothing with radius/diameter Dimensions so maybe it doesn't matter with them, but it should recognize and bypass angular and ordinate Dimensions, which it does funny things with [green are the Lines it draws]:
Kent Cooper, AIA
Message 5 of 9
cool.stuff
Many thanks 🙂 works perfectly 🙂
Message 6 of 9
cool.stuff
Many thanks 🙂 works like a charm 🙂
Message 7 of 9
cool.stuff
Thanks for the help @Kent1Cooper 🙂
I only have linear/aligned/rotated Dimensions, so I am very pleased with your solution 🙂
Again, many thanks for saving me hours of work 🙂
Message 8 of 9
Kent1Cooper
Come to think of it, the ignoring of the "wrong" varieties of Dimensions can be done within the object selection [line 3], rather than by accepting all Dimensions in selection and then checking each one in the processing:
  (/ ss n dim ddata)
  (if (setq ss (ssget '((0 . "DIMENSION") (-4 . "<NOT") (-4 . "&") (70 . 6) (-4 . "NOT>"))))
      (setq
        ddata (entget dim)
      ); setq
      ); command
    ); repeat
  ); if
  (prin1)
Kent Cooper, AIA
Message 9 of 9
komondormrex
althou i did mention that the code provided is the simplest one i suggest @cool.stuff a slightly complicated one, dealing  with aligned and rotated dims only
	  (if (member (cdr (assoc 100 (reverse dimension_dxf))) '("AcDbAlignedDimension" "AcDbRotatedDimension"))
  (princ)
