Using ACAD 2021: Looking for a LISP just like the Block COUNT command from AutoCAD 2022
thaydenCJMLL
Message 1 of 11
thaydenCJMLL
Does anyone know of a LISP that functions just like the new COUNT command introduced in ACAD 2022? I'm using AutoCAD 2021 - so I don't have access to the COUNT feature in newer versions of ACAD.
I came across something similar in another forum and I'm trying to work with it - but it requires a lot of nudging to get it to do what I want it to do:
  • Display a dialog with a block name list & quantity count of all first-level named blocks in Model Space (ignore nested blocks)
  • Allow the user to select a block name from the dialog and see all instances of that block highlighted (with Insert node visible, preferably)
  • Allow the user to zoom / pan around the drawing to look at the insertions of said block
  • And and also it would be ideal if all the non-selected entities (everything but the highlighted/selected block name) went to 50% dim/fade - tho I'm not even sure this is possible. The code below turns the non-selected blocks visibility off - but I need them to stay visible, just dim them down.
I'm conversant in LISP & VLISP - but I'm rusty after not using it for the past 4 years or so... but I'm happy to work with anything or guidance anyone can share. Thanks!
Here's what I've been working with so far (but I'm willing to go in a completely different direction if needed):
;;; Walk Blocks by Some Buddy for the CAD community.
;;; This program is freeware. Use it, change it, improve it, hack it as you wish :)
;;; Functions HIDEOTHERS and SHOWALL provided by balisteor
(defun walk_blocks (
                     activedoc
                     layers
                     getblocks
                     matched_blocks
                     hideothers
                     showall
                     highlightit
                     bbox->points
                     write_dcl_code_to
                     implied_selection
                     user_selection
                     tempfile
                     dclfile
                     what_next
                     dcl_id1
                     xref_flag
                     blockslist
                     selvalue
                     walk_type
                     selblock
                     next_block
                     dcl_ok
                     yes_no
                     refresh_list
                     spinning_wheel
                     alter_layers
                     restore_layers
                     implied_selection
                     blocksdata
                     blockslist
                     blockslayerslist
                     do_the_walk_type
                     tabbed_selblock
                     action_tile_blocks_list
                     action_tile_walk_type
                     action_tile_pan_zoom
                     action_tile_zoom_object
                     action_tile_zoom_previous
                     action_tile_select
                     action_tile_next
                     action_tile_cancel
                     what_next
  (vl-load-com)
  (setq activedoc (vla-get-activedocument (vlax-get-acad-object)))
  (setq layers (vla-get-layers activedoc))
  (defun *error* (s)
    (if *errdump* (vl-bt))
    (if dcl_ok
      (progn
        (unload_dialog dcl_id1)
        (vl-file-delete tempfile)
    (showall user_selection nil)
    (sssetfirst nil nil)
    (restore_layers blockslayerslist)
    (princ)
  (defun sset->vlsset (argsset / ssets vlssets assoc_list max_vlsset vlsset safe_array index)
    (setq ssets (vla-get-selectionsets activedoc))
    (vlax-for sset ssets
      (if (wcmatch (vla-get-name sset) "*`#VLSSET")
        (setq vlssets (cons (vla-get-name sset) vlssets))
    (foreach element vlssets
      (setq assoc_list
        (cons (cons (atoi element) element) assoc_list)
    (if (zerop (length assoc_list))
      (setq max_vlsset "0#VLSSET")
      (setq max_vlsset
        (cdr
          (car
            (vl-sort
              assoc_list
             '(lambda (x1 x2)(> (car x1)(car x2)))
    (setq vlsset
      (vla-add
        ssets
        (strcat (itoa (1+ (atoi max_vlsset))) "#VLSSET")
    (setq safe_array
      (vlax-make-safearray vlax-vbobject (cons 0 0))
    (setq index 0)
    (repeat (sslength argsset)
      (vlax-safearray-put-element
        safe_array
        0
        (vlax-ename->vla-object (ssname argsset index))
      (vla-additems vlsset safe_array)
      (setq index (1+ index))
    vlsset
  (defun countgroup (inlist / outlist existing_item)
    (vl-sort
      (foreach item inlist
        (if (not (member (assoc item outlist) outlist))
          (setq outlist (cons (cons item 1) outlist))
          (progn
            (setq existing_item
              (car (member (assoc item outlist) outlist))
            (setq outlist
              (subst
                (cons item (1+ (cdr existing_item)))
                existing_item
                outlist
     '(lambda(x y)(< (car x)(car y)))
  (defun addtabs (inlist / tabslist)
      (setq tabslist
        (cons
          (strcat
            (itoa (cdr item))
            "\t"
            (car item)
          tabslist
    (reverse tabslist)
;   (defun addtabs (inlist / tabslist)
;     (foreach item inlist
;       (setq tabslist
;         (cons
;           (strcat
;             (chr 40)
;             (cond
;               ( (< (cdr item) 10)
;                 "__"
;               ( (and
;                   (>= (cdr item)  10)
;                   (< (cdr item) 100)
;                 "_"
;               (T "")
;             (itoa (cdr item))
;             (chr 41)
;             "\t"
;             (car item)
;           tabslist
;     (reverse tabslist)
  (defun striptab (string)
    (substr string (+ (vl-string-position (ascii "\t") string) 2))
  (defun getblocks (
                     selection
                     xref_flag
                     layeron_flag
                     freeze_flag
                     locked_flag
                     is_object_valid
                     blocknameslist
                     blocklayer
    (defun is_object_valid (object xref_flag layeron_flag freeze_flag locked_flag)
      (if xref_flag
          (vla-get-objectname object)
          "AcDbBlockReference"
        (and
            (vla-get-isxref
              (vla-item
                (vla-get-blocks document)
                (vla-get-effectivename object)
            :vlax-false
    (vlax-for object (sset->vlsset selection)
      (if (is_object_valid object xref_flag layeron_flag freeze_flag locked_flag)
        (progn
          (setq blocknameslist
            (cons
              blocknameslist
          (setq blocklayer (vla-get-layer object))
          (setq currlaystatus
            (list
              blocklayer
              (cons "LayerOn" (vla-get-layeron (vla-item layers blocklayer)))
              (cons "Freeze" (vla-get-freeze (vla-item layers blocklayer)))
              (cons "Lock" (vla-get-lock (vla-item layers blocklayer)))
          (if (not (member currlaystatus blockslayerslist))
            (setq blockslayerslist (cons currlaystatus blockslayerslist))
    (if blocknameslist
      (list (acad_strlsort blocknameslist) blockslayerslist)
  ;;; Code provided by balisteor starts here
  (defun hideothers (selection blockname / index ent object layer layermode effname)
    (if selection
      (progn
        (set_tile "working" "Working: ")
        (repeat (setq index (sslength selection))
          (setq ent (ssname selection (1- index)))
          (setq object (vlax-ename->vla-object ent))
          (if
            (setq effname
              (vlax-property-available-p object 'effectivename)
            (if
                (strcase blockname)
                (strcase (vlax-get-property object 'effectivename))
              (if (vlax-property-available-p object 'Visible)
                (vlax-put-property object 'Visible -1)
                (vlax-put-property object 'Visible 0)
          (setq index (1- index))
          (set_tile "spinning_wheel" (spinning_wheel (get_tile "spinning_wheel")))
    (set_tile "working" "")
    (set_tile "spinning_wheel" "")
    (princ)
  ;;; Code provided by balisteor ends here
  (defun showall (selection flag / index ent object layer layermode)
    (if selection
      (progn
          (if (vlax-property-available-p object 'visible)
              (vlax-put-property object 'visible -1)
          (if flag
    (if flag
      (progn
    (princ)
  (defun highlightit (selection blockname flag / index ent object)
    (if selection
      (progn
          (if (vlax-property-available-p object 'effectivename)
            (if
                (strcase blockname)
              (progn
                (if flag
                  (vla-highlight object :vlax-true)
                  (vla-highlight object :vlax-false)
                (setq matched_blocks(cons object matched_blocks))
		;(sssetfirst nil selection) ;;turn the blue grips on
    (princ)
  (defun bbox->points (object)
    (if object
      (progn
        (vlax-invoke-method
          object
          'getboundingbox
          'minpoint
          'maxpoint
        (list minpoint maxpoint)
  (defun write_dcl_code_to (file)
    (write-line
      (strcat
        "listbox:dialog{"
           "label=\"Walk Blocks\";"
           "width=50;"
           ": spacer{"
              "height=0.01;"
           ": column{"
              "label=\"Select Block\";"
              ": text{"
                 "label=\"Refs     Block name\";"
              ": list_box{"
                 "key=\"blocks_list\";"
                 "allow_accept=true;"
                 "tabs=\"6\";"
                 "height=20;"
              ": button{"
                 "label=\"   Next >   \";"
                 "key=\"next\";"
                 "is_enabled=false;"
                 "is_default=true;"
           ": row {"
              ": boxed_radio_column{"
                 "label=\"Walking Type\";"
                 "key=\"walk_type\";"
                 ": spacer{"
                    "height=0.01;"
                 ": radio_button{"
                    "label=\"Isolate\";"
                    "key=\"isolate\";"
                 ": spacer{"
                    "height=1;"
                 ": radio_button{"
                    "label=\"Highlight\";"
                    "key=\"highlight\";"
                 ": spacer{"
                    "height=0.01;"
              ": boxed_column{"
                 "label=\"Zoom/Pan\";"
                 "fixed_width=true;"
                 "width=16;"
                 ": button{"
                    "label=\"General Pan/Zoom\";"
                    "key=\"pan_zoom\";"
                 ": button{"
                    "label=\"Zoom To Block\";"
                    "key=\"zoom_object\";"
                 ": button{"
                    "label=\"Zoom Previous\";"
                    "key=\"zoom_previous\";"
           ": row {"
              "alignment = centered;"
               ": spacer{"
                  "width=0.01;"
              ": button{"
                 "label=\"  Select >  \";"
                 "key=\"select\";"
                ": spacer{"
                   "width=1;"
              ": button{"
                 "label=\"    Close    \";"
                 "key=\"cancel\";"
                 "is_cancel=true;"
              ": spacer{"
                 "width=0.01;"
           ": row{"
              ": concatenation{"
                 ": text_part{"
                    "key=\"working\";"
                    "width=9;"
                 ": text_part{"
                    "key=\"spinning_wheel\";"
        "yes_no:dialog{"
           "label=\"Walk Blocks Question\";"
           ": text{"
              "key=\"message1\";"
              "alignment=centered;"
              "width=37;"
           ": text{"
              "key=\"message2\";"
              "width=37;"
           ": row{"
              "fixed_width=true;"
              ": button{"
                 "label=\"Yes\";"
                 "key=\"accept\";"
                 "fixed_width=true;"
                 "width=12;"
              ": button{"
                 "label=\"No\";"
                 "key=\"cancel\";"
                 "fixed_width=true;"
                 "width=12;"
                 "is_default=true;"
                 "is_cancel=true;"
      file
  (defun yes_no (message1 message2 / dcl_id2)
    (setq dcl_id2 (load_dialog tempfile))
    (if (not (new_dialog "yes_no" dcl_id2 "" yes_no_DCL_position))
      (progn
        (alert "Dialog definition not found.")
        (exit)
    (set_tile "message1" message1)
    (set_tile "message2" message2)
    (action_tile "accept" "(setq yes_no_DCL_position (done_dialog 1))")
    (action_tile "cancel" "(setq yes_no_DCL_position (done_dialog 0))")
    (setq answer (start_dialog))
    (unload_dialog dcl_id2)
    answer
  (defun refresh_list (key lst)
    (start_list key)
    (mapcar 'add_list lst)
    (end_list)
  (defun spinning_wheel (wheel)
    (cond
      ( (= wheel  "|") "/")
      ( (= wheel  "/") "-")
      ( (= wheel  "-") "\\")
      (T "|")
  (defun alter_layers (blockslayerslist)
    (setq current_layer (vla-get-activelayer activedoc))
    (vla-add layers "temp")
    (vla-put-activelayer activedoc (vla-item layers "temp"))
    (foreach item blockslayerslist
      (vla-put-layeron (vla-item layers (car item)) :vlax-true)
      (vla-put-freeze (vla-item layers (car item)) :vlax-false)
      (vla-put-lock (vla-item layers (car item)) :vlax-false)
    ;(command "_.layer" "_oN" "DEFPOINTS" "" "")
    ;ADD CODE TO TURN ON DEFPOINTS HERE
  (defun restore_layers (blockslayerslist / layer_temp)
      (vla-put-layeron (vla-item layers (car item))(cdr (assoc "LayerOn" (cdr item))))
      (vla-put-freeze (vla-item layers (car item))(cdr (assoc "Freeze" (cdr item))))
      (vla-put-lock (vla-item layers (car item))(cdr (assoc "Lock" (cdr item))))
    (vla-put-activelayer activedoc current_layer)
    (if
      (not
        (vl-catch-all-error-p
          (setq layer_temp
            (vl-catch-all-apply 'vla-item (list layers "temp"))
      (vla-delete layer_temp)
  (setq implied_selection (ssgetfirst))
  (if
    (and
      (not (setq user_selection (cadr implied_selection)))
      (not (setq user_selection (car implied_selection)))
    ;(setq user_selection (ssget))
    (setq user_selection (ssget '((0 . "INSERT, MTEXT") (-4 . "<NOT") (8 . "DEFPOINTS") (-4 . "NOT>"))))
    ;(setq user_selection (ssget '((0 . "MTEXT,INSERT") (-4 . "<NOT") (8 . "DEFPOINTS") (-4 . "NOT>"))))
    ;(setq user_selection (ssget (8 . "DEFPOINTS")))
    ;(setq user_selection (ssget (-4 . "<NOT") (8 . "DEFPOINTS") (-4 . "NOT>")))
  (setq what_next 1)
  (while (> what_next 0)
    (if user_selection
      (progn
        (setq blocksdata (getblocks user_selection T nil nil nil))
        (setq blockslist (addtabs (countgroup (car blocksdata))))
        (setq blockslayerslist (cadr blocksdata))
        (if blocksdata
          (progn
            (setq dcl_ok T)
            (setq tempfile (vl-filename-mktemp "tempfile.dcl"))
            (setq dclfile (open tempfile "w"))
            (write_dcl_code_to dclfile)
            (close dclfile)
            (setq dcl_id1 (load_dialog tempfile))
            (if (not (new_dialog "listbox" dcl_id1 "" walk_blocks_DCL_position))
              (progn
                (exit)
            (alter_layers blockslayerslist)
            (refresh_list "blocks_list" blockslist)
            (if selblock
              (progn
                (set_tile
                  "blocks_list"
                  (if (not (wcmatch selblock "*`\t*"))
                    (itoa (vl-position tabbed_selblock blockslist))
                    (itoa (vl-position selblock blockslist))
                (mode_tile "next" 0)
            (if (not walk_type)(setq walk_type "highlight"))
            (set_tile "walk_type" walk_type)
            ;;(if xref_flag
            ;; (set_tile "include_xrefs" "1")
            ;; (set_tile "include_xrefs" "0")
            (defun do_the_walk_type (walk_mode)
              (if selblock
                (if (= walk_mode "isolate")
                  (progn
                    (highlightit user_selection selblock nil)
                    (hideothers user_selection selblock)
                  (progn
                    (showall user_selection T)
                    (highlightit user_selection selblock T)
                (progn
                  (alert "Nothing selected.")
            (defun action_tile_blocks_list (value)
              (setq selvalue value)
              (setq tabbed_selblock (nth (atoi selvalue) blockslist))
              (setq selblock (striptab (nth (atoi selvalue) blockslist)))
              (do_the_walk_type walk_type)
            (defun action_tile_walk_type (value)
              (setq walk_type value)
            ;;(defun action_tile_include_xrefs (value)
            ;;  (alert "value")
            (defun action_tile_pan_zoom ()
              (setq walk_blocks_DCL_position (done_dialog 1))
            (defun action_tile_zoom_object ( / ll ur)
              (if matched_blocks
                (progn
                  (vla-getboundingbox  (car matched_blocks) 'll 'ur)
                  (vla-zoomwindow (vlax-get-acad-object) ll ur)
                (progn
            (defun action_tile_zoom_previous ()
              (if matched_blocks
                (vla-zoomprevious (vlax-get-acad-object))
            (defun action_tile_select ()
              (if
                (not
                  (zerop
                    (yes_no
                      "Do you really want to discard the current"
                      "selection set and make a new selection ?"
                (setq walk_blocks_DCL_position (done_dialog 2))
            (defun action_tile_next ( / item)
              (setq item (atoi (get_tile "blocks_list")))
              (if (= item (1- (length blockslist)))
                (progn
                  (set_tile "blocks_list" "0")
                  (setq tabbed_selblock (nth 0 blockslist))
                  (setq selblock (striptab (nth 0 blockslist)))
                (progn
                  (set_tile "blocks_list" (itoa (1+ item)))
                   (setq tabbed_selblock (nth (1+ item) blockslist))
                  (setq selblock (striptab (nth (1+ item) blockslist)))
            (defun action_tile_cancel ()
              (setq walk_blocks_DCL_position (done_dialog 0))
            (action_tile "blocks_list" "(action_tile_blocks_list $value)")
            (action_tile "walk_type" "(action_tile_walk_type $value)")
            ;;(action_tile "include_xrefs" "(action_tile_include_xrefs $value)")
            (action_tile "pan_zoom" "(action_tile_pan_zoom)")
            (action_tile "zoom_object" "(action_tile_zoom_object)")
            (action_tile "zoom_previous" "(action_tile_zoom_previous)")
            (action_tile "select" "(action_tile_select)")
            (action_tile "next" "(action_tile_next)")
            (action_tile "cancel" "(action_tile_cancel)")
            (setq what_next (start_dialog))
            (cond
              ( (= what_next 1)
                (getstring
                  "\nUse mouse wheel to Zoom and Pan, press [Enter] when done: "
              ( (= what_next 2)
                (setq selblock nil)
                (setq blockslist nil)
                (setq blockslayerslist nil)
	       ;(setq user_selection (ssget ((-4 . "<NOT") (8 . "DEFPOINTS") (-4 . "NOT>"))))
          (progn
            (alert "No block found in the selection.")
            (setq what_next 0)
      (progn
        (setq what_next 0)
  (princ)
(defun c:wkbks ()(walk_blocks)(princ))
(prompt "\n *** Walk Blocks loaded. Type 'WKBKS' to run the utility ***")(princ)
Replies (10)
Message 2 of 11
pendean
Community Legend
Community Legend
May I ask why you need a LISP that works exactly like an existing tool?
Message 3 of 11
thaydenCJMLL
I/we have ACAD 2021 (COUNT was released w/ ACAD 2022). That decision is beyond my paygrade at the moment, and my team needs a solution before we move to the next version.
Message 4 of 11
pendean
Community Legend
Community Legend
Ah, so you are stuck in 2021 with no option to change. Got it. Why not say so in your first post? and title too, so it can get the attention it needs?
Before 2022's COUNT, we all used QSELECT or FILTER or SELECTSIMIALR commands for the basics, DATAEXTRACTION for more complex needs, and LISPs like these depending on needs
https://lee-mac.com/blockcounter.html
https://lee-mac.com/dynamicblockcounter.html
https://lee-mac.com/nestedblockcounter.html
https://lee-mac.com/selectioncounter.html
https://apps.autodesk.com/ACD/en/Detail/Index?id=2167190461193733548&appLang=en&os=Win32_64
or buy something
https://apps.autodesk.com/ACD/en/Detail/Index?id=8023557257185740809&appLang=en&os=Win32_64
What exact "counting" need are you trying to solve (or disparately need) exactly?
No offense to the A-team that introduced COUNT in 2022, but it's lame, it's much improved in 2024/2025 IMHO.
Message 5 of 11
thaydenCJMLL
Thanks (and I'll updated my post title- thanks for the advice)!
I'm familiar with Lee Mac's stuff.  Some parts work for what we need - and yes, we were contemplating just using SelectSimilar to have the blocks highlight.
Our Use Case:
This is for blocks of partial floorplans; non-attributed & non-dynamic blocks. They go together like puzzle pieces...to form different versions of  a "whole house plan". There may be 40 "whole house plans" in model space, comprised of a jigsaw of these partial plan blocks.
This is part of an internal QC process to confirm that each block is where it should be, and to confirm what "whole house floorplan" it's part of.
  • That's why it's useful to see a list of the block names (helps us to confirm they conform to a predetermined block naming convention).
  • The count of block inserts is useful - that also helps us confirm no partial plans are missing from where they are expected to be (or too many have been inserted).
  • And since these blocks can go together to form a "whole house plan", we want to know which partial floor plan block is located in which "whole house plan" to confirm it's where it should be - and to ensure that block has been inserted in all the "whole house plans" it's supposed to. So zooming & panning once the block inserts are highlighted.
A dialog box interface is useful. There are many "block count" routines out there that will count & list block names but spit results to the Text Window or XLS/CSV....  we don't need to save this info; we just want to see a list of block names and then go down that list of named block inserts, and select each block name to see where in model space each insert is located (and also see the geometry of that block).
Message 6 of 11
thaydenCJMLL
Incidentally, if I use Lee Mac's "Block Counter" to put all the blocks inserts into their own cells in a table, how do I use SELECTSIMILAR, since I can't seem to actually select the block in the cell of the table.
This would be a good stop-gap if we could get THIS to work.
Message 7 of 11
pendean
Community Legend
Community Legend
...I can't seem to actually select the block in the cell of the table...
No core command does that.
Message 8 of 11
Sea-Haven
Breaking it down into steps this is 1st step, unless you have a list of block names.
(defun c:wow ( / lst bname block lst2)
(if (not LM:ListBox2)(load "lee-mac list box-2"))
(setq lst '())
(vlax-for block (vla-get-blocks (vla-get-ActiveDocument (vlax-get-acad-object)))
(setq bname (vlax-get block 'Name))
(if (= (substr bname 1 1) "*")
(princ)
(setq lst (cons bname lst))
(setq lst (vl-sort lst '<))
(setq lst2 (LM:ListBox2 "Please choose" lst nil T))
; do next step here
(princ)
(c:wow)
Step 2 "helps us to confirm they conform to a predetermined block naming convention" you could compare the block list of names picked to some sort of rule but you have not indicated those rules.
Step 3 next. count of block inserts is useful to a table is easiest to read, just erase after checking.
Message 9 of 11
Sea-Haven
Step 3, dont know what size for table text etc so uses default table settings.
; https://forums.autodesk.com/t5/visual-lisp-autolisp-and-general/using-acad-2021-looking-for-a-lisp-just-like-the-block-count/td-p/12851618
(defun c:wow ( / lst bname block lst2 lst3 x ss bstr)
(setq lst '())
(princ)
; do next step here
(setq bstr "")
(setq bstr (car lst2))
(setq x 0)
(repeat  (- (length lst2) 1)
(setq bstr (strcat Bstr "," (nth (setq x (1+ x)) lst2)))
(setq ss (ssget "x" (list (cons 0 "INSERT")(cons 2 bstr))))
(if (= ss nil)
(progn (alert "no text picked")(exit))
(setq lst '() lst3 '())
(repeat (setq x (sslength ss))
(setq txt (cdr (assoc 2 (entget (ssname ss (setq x (1- x)))))))
(setq lst (cons txt lst))
(setq lst2 (remove_doubles lst))
(foreach val lst2
(setq cnt (my-count val lst))
(setq lst3 (cons (list val cnt) lst3))
(setq sp (vlax-3d-point (getpoint "pick a point for table")))
(Setq vgms (vla-get-modelspace (vla-get-activedocument (vlax-get-acad-object))))
(setq numrows 3)
(setq numcolumns 2)
(setq rowheight 3.)
(setq colwidth 60)
(setq objtable (vla-addtable vgms sp numrows numcolumns rowheight colwidth))
(vla-settext objtable 0 0 "Blocks")
(vla-settext objtable 1 0 "Blk Name")
(vla-settext objtable 1 1 "Count")
(setq rowcnt 3)
(setq rowhgt (vla-getRowHeight objtable 2))
(foreach val lst3
  (vla-InsertRows objTable rowcnt rowhgt 1)
  (vla-settext objtable (- rowcnt 1) 0 (car val))
  (vla-settext objtable (- rowcnt 1) 1 (cadr val))
  (setq rowcnt (1+ rowcnt))
(princ)
(c:wow)
Step 4 need a dwg maybe not sure about what to do.
Message 10 of 11
thaydenCJMLL
Thanks everyone who shared their ideas and insight! I found I can get the job done with the "Find Non-Purgeable Items" of the "Purge" Dialog BoxNon-Purgeable.png:
Message 11 of 11
Sea-Haven
If you do not have nested blocks you can just get all block names that are currently being used in say Model space that is a SSGET function with filters. Then do the count for each one. Using purge may not distinguish between nested blocks and single blocks as it returns used blocks. It would include also blocks in layouts.
