Updateing Attribute in layout tabs
I'm trying to write a Lisp routine that will update a date attribute in all the layout tabs in my dwg.
I have successfully wrote one for a single tab dwg but now want the routine to the same but for all layouts in my dwg.
Here is what i have done so far.
The routine scrolls thru the layouts but only updates the Date attribute on the last tab
(defun C:PDT()
;(setvar "cmdecho" 0)
(setq today (menucmd "m=$(edtime,$(getvar,date),mo.dd.yy)"))
(setq Tag (ssget "x" (list (cons 0 "insert") (cons 2 "ttlblk-attribute"))))
(setq Block (entget (ssname Tag 0)))
(setq Att (entget (entnext (cdr (assoc -1 Block)))))
(setq OldDate (cdr (assoc 1 Att)))
(setq Data (subst (cons 1 OldDate) (assoc 1 Att) Att))
(entmod Data)
(foreach layout (layoutlist)
(setvar "ctab" layout))
(command ".-attedit" "n""n" "*" "XX-XX-XXXX" "" OldDate today)
;(command "graphscr")
;(setvar "cmdecho" 1)
(PRINC))
I have been scrolling thru the forums here but can't find something that helps me get over the final hurdle.
from info gained from the forums I thought the above would get a list of the layouts and switch from layout to layout and execute the command??
Any and all help much appreciated.
Thx in advance
Paul
Ok on further trial and error below seems to work
One funny incident on One Dwg, my working Dwg, it places the date on the first layout twice but on other dwgs it works fine.
