Conflict with Xref and block inserted. How solve this problem?
ladimirabdala
ladimirabdala
I have a routine to insert A4 A3 A2, but if a block is already in the drawing, appear the messsage:
** Error: "A4v" is already a standard block in the current drawing. *Invalid*
And my routine is canceled. How make this?
Purge is not efficient.
Purge, though inefficient, is probably the best way.
You could rename the internal block or rename the xref.
You could write your own routine to delete the block or to convert it into the xref.
You could use the Express Tools BlockToXref feature.
wrote in message news:5691596@discussion.autodesk.com...
messsage:
If the new block is to redefine the old block then insert old=new.
Otherwise, you can check first to see if the block name is already used, and
if so then you could rename before trying to insert the new name.
*Invalid*
