Update Multi-Line attribute with LISP
vrod_2000
vrod_2000
I have a LISP routine where I am replacing an attribute value.
It worked fine until I changed the attribute within the block to a multi-line attribute.
I am only going to use a single line of text in it. (It is multi-line so a text mask can be used)
here is the code snippet that used to work...
(setq INSTELEV "EL.")
(setq ATT3 (subst (cons 1 INSTELEV) (assoc 1 ATT3) ATT3))
(entmod ATT3)
thanks for any ideas!
cadffm
Check the entitylist of single and multiline attributes..
Check what (assoc 1 att3) will find => every time only the first hit in the list.
(setq ATT3 (subst (cons 1 INSTELEV) (assoc 1 (reverse ATT3)) ATT3))
(entmod ATT3)
Ans SUBST change ALL matches (if the first and the second dxf-1 has the same value..),
so subst works, but it isn't perfect - would the teacher say.
since I assume that the first dxf-1 dottedpair actually should always have the value "".
But I do not know any problems with using a different value there, it just gets overruled, I think.
Sebastian
vrod_2000
(humble bow)
supreme awesomeness!
