(vlax-create-object "ScriptControl") retuns nil
SAPER59
SAPER59
I'm tryng to run a function that got from the web, to display an image in DCL but (vlax-create-object "ScriptControl") can not access and null object is returned
Working in Windows 10 64b
Any help about how to solve this will be thanks
dlanorh
I can't find the reference but the problem may be that this is only compatible with 32-bit systems.
Post the function.
I am not one of the robots you're looking for
SAPER59
OK, thanks
SAPER59
I forgot to post the function
(defun get_cb (/ scr txt) ;
(setq scr (vlax-create-object "ScriptControl"))
(vlax-put scr 'language "vbs")
(vlax-invoke-method
scr
'ExecuteStatement
"Set htmlfile = CreateObject(\"htmlfile\")
Text = htmlfile.ParentWindow.ClipboardData.GetData(\"text\")"
(setq txt (vlax-invoke-method scr 'eval "Text"))
(vlax-release-object scr)
txt
) ;_ end of defun
ronjonp
These get and set clipboard functions still work.
