Unfolding 3d Solids
Unfolding 3d Solids
Unfolding 3d Solids
I import 3d sheet metal part solids in AutoCAD, and I want unfolding it.
I tried got the 3d solid object entity and property , but I don't know which one can help me unfolding the 3d solid.
Does anyone have any idea on how can I unfold solids using Lisp or visual lisp?
dgorsman
Not directly possible with LISP.  And while you could bootstrap it with some dotNET-defined LISP functions, the complexity will still be significant.  Do you already have the math/algorithms for doing this?
stevor
One way to get some info, is to explode a copy of the 3DSolid. Search 'explode 3d solid autolisp.'
S
Hi dgorsman, stevor
I only understand Lisp and Visual Lisp , I can't use dotNET....
I tried a math/algorithms, like this:
1. copy a 3d solid and explode the solid, got all region and surface
2. used two main region and get the solid thickness
3. erase region with equal thickness, leaving only a continuous surface
4. rotate and move all region to same plane, and add KFactor between region
But I don't know how to determine which region should be connected which region
because steel solids are variety, especially fold not one side.......
kindly help me out.
wkmvrij
brianyUL99V
You are on the right path. Everything I’m about to say applies to air bending with a .030” radius top punch.
Most Sheet Metal shops/ brake operators do not use K factor as it only applies to large radius bends, and is still a guess. Each material type (ferrous/nonferrous) has a bend deduction. For ferrous we use 100% material thickness, for nonferrous 80%. Using .125” material for both. Assuming your Zee brake shape was 1”x1”x1” OD/Outside Diameter you would get the following length flat patterns by adding up from edge to bend to bend to edge:
Ferrous/Steel=.875+.75”+.875”=2.5”
Nonferrous/Aluminum=.9”+.8”+.9”= 2.6”
a lookup function using a table could easily perform this while allowing variables.
