Round up numbers
Round up numbers
andreas7ZYXQ
Message 1 of 11
Round up numbers
andreas7ZYXQ
Is it possible to round up numbers like..
2.1 = 3
2.5 = 3
I can only use normal math rules now. But im searching for a other way. Any ideas?
Replies (10)
Message 2 of 11
ВeekeeCZ
Most simple is
(rtos (+ 2. 0.49) 2 0)
But if you actually DO a search, you'll find plenty of solutions.
Message 3 of 11
_gile
Here's a way:
;; round up
(defun ceil (x / n)
  (if (or (= (setq n (fix x)) x) (< x 0))
    n
    (1+ n)
;; round down
(defun floor (x / n)
  (if (or (= (setq n (fix x)) x) (< 0 x))
    n
    (1- n)
Gilles Chanteau
GileCAD
GitHub
Message 4 of 11
andreas7ZYXQ
Thanks!
Great solution
Message 5 of 11
john.uhden
0.49??  Is your inflation driving down the value of numbers?
Um, how about (fix (+ n 0.5))?
I've got something back home that can round to any precision, but I forget the code.
It might help if we had a reverse exponent function, as in (expt 10 n) = 100 and solve for n.
Maybe...
(defun revexpt (val n / exp)
  (setq exp 1)
  (while (/= val n)
    (setq exp (1+ exp))
    (setq val (/ val (expt n exp)))
  (1+ exp)
No good... "divide by zero" sometimes
John F. Uhden
Message 6 of 11
_gile
;; round
(defun round (x)
  (fix ((if (minusp x) - +) x 0.5))
;; round to
(defun roundTo (num prec)
  (if (zerop (setq prec (abs prec)))
    num
    (* prec
       (fix ((if (minusp num)
              (/ num prec)
              0.5
;; round up
(defun ceil (x / n)
    n
    (1+ n)
;; round down
    n
    (1- n)
_$ (roundTo 0.49 0.1)
0.5
_$ (round 0.49)
0
0.5
_$ (ceil 0.49)
1
_$ (floor 0.49)
0
_$ (round pi)
3
_$ (roundTo pi 0.01)
3.14
_$ (ceil pi)
4
_$ (floor pi)
3
Gilles Chanteau
GileCAD
GitHub
Message 7 of 11
john.uhden
minusp...  EXCELLENT!
John F. Uhden
Message 8 of 11
ВeekeeCZ
I've meant (rtos (+ x 0.49) 2 0) for round up. Still most simple I think.
But sure, it converts a result into string, so @_gile's suggestions are proper solutions.
Message 9 of 11
Kent1Cooper
That depends on the precision of your number argument.  It wouldn't  round 6.009 up to 7.
But if the numbers are of no more than two decimal places and that's precise enough, you could, of course, wrap the whole thing in (atoi) to return an integer.
Kent Cooper, AIA
Message 10 of 11
john.uhden
Somewhere in my education I was taught to round even numbers down and odd numbers up.
2.5 => 2
3.5 => 4
I guess that would involve something like
(if (> (rem n 2) 1) => odd
John F. Uhden
Message 11 of 11
_gile
2.5 => 2
3.5 => 4
It is just one convention among others.
Gilles Chanteau
GileCAD
GitHub
