Unable to save ... being accessed by another session
hencoop
Advisor Advisor
hencoop
Hello all,
There are apparently several reasons for AutoCAD to return this error.  In each case, something has flagged the drawing as "open".  Today, I discovered one reason that may be as elusive to others just as it was to me.
 The reason the drawing was flagged as open is that the object assigned to *active-document* by
(SETQ *active-document* (vla-get-activedocument (vlax-get-acad-object)))
(and which could be assigned to another symbol by similar code you may use) had not been released, i.e.,
(vlax-release-object *active-document*)
had not been done executed when the function making use of *active-document* had completed.
This file save error seemed random and was infrequent.
Before this, it had seemed to me that meticulously releasing and reacquiring the document object was excessive.  Now, I don't think it is!
AutoCAD User since 1989. Civil Engineering Professional since 1983
Product Version: 13.6.1963.0 Civil 3D 2024.4.1 Update Built on: U.202.0.0 AutoCAD 2024.1.6
                        27.0.37.14 Autodesk AutoCAD Map 3D 2024.0.1
                        8.6.52.0 AutoCAD Architecture 2024
john.uhden
@hencoop ,
Nice work.  Please accept your own solution.
I wonder if localizing *active-document* would circumvent that situation.
John F. Uhden
