export all line coordinates left to right or bottom to top
vishalghuge2500
Message 1 of 9
vishalghuge2500
Im looking for a code which can extract coordinates of lines like -
for Horizontal lines - excel's first two columns will have left coordinates (red) and next columns will have right coordinates (green)..
for vertical lines - excel's first two columns will have bottom coordinates (red) and next columns will have top coordinates (green).
during export it should not consider start point and end point concept of lines.
i have drawn some lines by clicking top to bottom  & bottom to top also for horizontal lines - left to right & right to left
I failed so
please give it a try,
Replies (8)
Message 2 of 9
daniel_cadext
Sorry for using the wrong language, but I wanted to play
import PyRx as Rx
import PyGe as Ge
import PyGi as Gi
import PyDb as Db
import PyAp as Ap
import PyEd as Ed
import traceback
import openpyxl as Ex  # using openpyxl
def PyRxCmd_doit():
    try:
        filter = [(Db.DxfCode.kDxfStart, "LINE")]
        ssres = Ed.Editor.select(filter)
        if ssres[0] != Ed.PromptStatus.eNormal:
            return
        doubles = [[]]
        vx = Ge.Vector3d.kXAxis
        vy = Ge.Vector3d.kYAxis
        tol = Ge.Tol()
        tol.setEqualVector(0.0001)
        for id in ssres[1].objectIds():
            line = Db.Line(id)
            sp = line.startPoint()
            ep = line.endPoint()
            seg = Ge.LineSeg3d(sp, ep)
            segdir = seg.direction()
            if vx.isParallelTo(segdir, tol):
                if vx.isCodirectionalTo(segdir, tol):
                    doubles.append([sp.x,sp.y,ep.x,ep.y])
                else:
                    doubles.append([ep.x,ep.y,sp.x,sp.y])
            elif vy.isParallelTo(segdir, tol):
                if vy.isCodirectionalTo(segdir, tol):
                else:
        # create a workbook and get the active sheet
        wb = Ex.Workbook()
        ws = wb.active
        for nrow, i in enumerate(doubles):
            for ncol, j in enumerate(i):
                ws.cell(row=nrow+1, column=ncol+1, value=j)
        wb.save('e://pyout.xlsx')
    except Exception as err:
        traceback.print_exception(err)
Python for AutoCAD, Python wrappers for ARX https://github.com/CEXT-Dan/PyRx
Message 3 of 9
ВeekeeCZ
Try this
(vl-load-com)
(defun c:LineCoordsCSV ( / *error* i f s d b e)
  (defun *error* (errmsg)
    (if (not (wcmatch errmsg "Function cancelled,quit / exit abort,console break,end"))
      (princ (strcat "\nError: " errmsg)))
    (if f (close f))
    (princ))
  (if (and (setq f (open (getfiled "Define name of exported file" (getvar 'DWGPREFIX) "csv" 1) "a"))
	   (setq s (ssget '((0 . "LINE"))))
	   (write-line "sx,sy,ex,ey,,dir" f)
    (repeat (setq i (sslength s))
      (if (and (setq d (entget (ssname s (setq i (1- i)))))
	       (setq b (cdr (assoc 10 d)))
	       (setq e (cdr (assoc 11 d))))
	(write-line
	  (if (equal (car b) (car e) 1e-6)
	    (if (> (cadr e) (cadr b))
	      (strcat (rtos (car b) 2 3) "," (rtos (cadr b) 2 3) "," (rtos (car e) 2 3) "," (rtos (cadr e) 2 3) ",," "V - LINES")
	      (strcat (rtos (car e) 2 3) "," (rtos (cadr e) 2 3) "," (rtos (car b) 2 3) "," (rtos (cadr b) 2 3) ",," "V - LINES"))
	    (if (> (car e) (car b))
	      (strcat (rtos (car b) 2 3) "," (rtos (cadr b) 2 3) "," (rtos (car e) 2 3) "," (rtos (cadr e) 2 3) ",," "H - LINES")
	      (strcat (rtos (car e) 2 3) "," (rtos (cadr e) 2 3) "," (rtos (car b) 2 3) "," (rtos (cadr b) 2 3) ",," "H - LINES")))
	  f))))
  (*error* "end")
Message 4 of 9
komondormrex
or this one
(defun get_csv_filename (extension / output_name csv_filename)
	(setq output_name (strcat (vlax-get (vla-get-activedocument (vlax-get-acad-object)) 'path)
							  (vl-filename-base (vlax-get (vla-get-activedocument (vlax-get-acad-object)) 'name))
	(if (type acet-ui-getfile)
			(setq csv_filename (acet-ui-getfile "Enter name of CSV file"
								 output_name
								 extension
								 1
			(setq csv_filename (getfiled "Enter name of CSV file"
							  output_name
							  extension
							  1
	(if (= "" csv_filename)
		nil
		csv_filename
(defun c:lines_lr_bt (/ line_list h_line_list v_line_list csv_filename_full csv_id)
	(setq line_list (mapcar 'vlax-ename->vla-object (vl-remove-if 'listp (mapcar 'cadr (ssnamex (ssget '((0 . "line")))))))
		  h_line_list (vl-remove-if-not '(lambda (line) (or (equal 0 (vla-get-angle line) 1e-3)
													  	  	(equal pi (vla-get-angle line) 1e-3)
								 	   	 line_list
		  h_line_list (mapcar '(lambda (line) (vl-sort (list (vlax-get line 'startpoint) (vlax-get line 'endpoint))
		  											  '(lambda (start end) (< (car start) (car end)))
							   h_line_list
		  v_line_list (vl-remove-if-not '(lambda (line) (or (equal (* 0.5 pi) (vla-get-angle line) 1e-3)
													    (equal (* 1.5 pi) (vla-get-angle line) 1e-3)
									     line_list
		  v_line_list (mapcar '(lambda (line) (vl-sort (list (vlax-get line 'startpoint) (vlax-get line 'endpoint))
		  											  '(lambda (start end) (< (cadr start) (cadr end)))
							   v_line_list
		  line_list (append (mapcar '(lambda (line) (cons "Hor" line)) h_line_list)
							(mapcar '(lambda (line) (cons "Ver" line)) v_line_list)
	(if (setq csv_filename_full (get_csv_filename "csv"))
		(progn
			 (setq csv_id (open csv_filename_full "w"))
			 (foreach line line_list
			 	(princ (car (nth 1 line)) csv_id)
				(princ "," csv_id)
			 	(princ (cadr (nth 1 line)) csv_id)
				(princ "," csv_id)
			 	(princ (car (nth 2 line)) csv_id)
				(princ "," csv_id)
			 	(princ (cadr (nth 2 line)) csv_id)
				(princ ",," csv_id)
				(princ (car line) csv_id)
				(princ "\n" csv_id)
			(close csv_id)
	(princ)
Message 5 of 9
vishalghuge2500
@ВeekeeCZ @komondormrex  thank you.
one more thing.
can we group these exported lines?
Message 6 of 9
komondormrex
possible way to solve it may be joining all lines into plines with autocad command then explode each pline joined and output coordinates as per each line of exploded pline.
Message 7 of 9
komondormrex
somewhat like this
								 output_name
								 extension
								 1
							  output_name
							  extension
							  1
		nil
		csv_filename
(defun c:lines_lr_bt (/ last_object_number lines_sset pline_list csv_filename_full csv_id line_list line_list_delete)
	(setq last_object_number (vla-get-count (vla-get-block (vla-get-activelayout (vla-get-activedocument (vlax-get-acad-object)))))
		  lines_sset (ssget '((0 . "line")))
	(setvar 'cmdecho 0)
	(command "_copy" lines_sset "" '(0 0) '(0 0))
	(command "_pedit" "_m" lines_sset "" "_y" "_j" "" "")
	(setvar 'cmdecho 1)
	(repeat (- (vla-get-count (vla-get-block (vla-get-activelayout (vla-get-activedocument (vlax-get-acad-object))))) last_object_number)
		(setq pline_list (append pline_list (list (vla-item (vla-get-block (vla-get-activelayout (vla-get-activedocument (vlax-get-acad-object)))) last_object_number)))
		      last_object_number (1+ last_object_number)
			(progn
				(foreach pline pline_list
					(setq line_list (mapcar '(lambda (line) (cond
													(cons "Hor"
													(cons "Ver"
												( t )
							 (setq line_list_delete (vlax-invoke pline 'explode))
					(mapcar 'vla-erase line_list_delete)
						(princ "," csv_id)
						(princ "," csv_id)
						(princ "," csv_id)
						(princ ",," csv_id)
						(princ "\n" csv_id)
					(princ ",\n" csv_id)
				  	(vla-erase pline)
				(close csv_id)
	(princ)
Message 8 of 9
vishalghuge2500
@komondormrex
Command: LINES_LR_BT
Select objects: Specify opposite corner: 19 found
Select objects:
; error: bad argument type: consp T
Message 9 of 9
komondormrex
post a file with error.
