Turn sheet set off and on via lisp
jwright1962
Message 1 of 9
jwright1962
Hello Forum:
is there a lisp or even the command that i can add to a toolbar button that toggles the sheet set palette on or off.
thanks for replies in advance.
Replies (8)
Message 2 of 9
paullimapa
@jwright1962
You can use lisp to check the following:
ssmstate
(getvar “ssmstate”)
if 0 then run command “sheetset” to open the ssm palette
(command “sheetset”)
if 1 then run command “sheetsethide” to close the ssm palette
(command “sheetsethide”)
FYI:
When opening drawing set SSMAUTOOPEN to:
0 to not open ssm palette
1 to open ssm palette
https://help.autodesk.com/view/ACD/2025/ENU/?guid=GUID-81EC988C-AAEA-4CC8-ADC5-D636CE82F677
Paul Li
IT Specialist
@The Office
Message 3 of 9
Moshe-A
@jwright1962 ,
CTRL+4  ; turn on / off sheetset manager.
it is defined in CUI command under ACAD\Keyboard Shortcuts.
Message 4 of 9
jwright1962
winner winner chicken dinner!   (command "sheetsethide")...   who would have thought...
Message 5 of 9
jwright1962
i have a very simple lisp that turns off all the palettes and then turns them back on via a toolbar button click.  was having trouble the sheetset.   thanks so much for your help
Message 6 of 9
paullimapa
Cheers!!!
Paul Li
IT Specialist
@The Office
Message 7 of 9
BlackBox_
This is already part of the AutoCAD Ribbon UI... 'View' tab, 'Palettes' panel, 'Sheet Set Manager' button.
"How we think determines what we do, and what we do determines what we get."
Sincpac C3D ~ Autodesk Exchange Apps
Message 8 of 9
jwright1962
i guess i didn't realize that.   my goal was to gather all the palettes up and turn them on and off as group.   i have that now, and thanks again to the forum.
Just as a side note, my screen space is somewhat limited.   i prefer to have the palettes on, generally speaking.  clicking them all on or all off one at a time as many times as i do it, just seemed a bit tedious.  much better now.
Message 9 of 9
BlackBox_
Glad you got what you were after.
For that, I just use Cleanscreen (Ctrl + 0).
Cheers
