Trying to select multiple windows get total area??
DC-MWA
Message 1 of 11
DC-MWA
I figured out how to get the area from aec windows. Now I'm trying to select mutiple windows and get the total area.
I think I'm close but....
I appreciate any input I can get.
Thanks.
File attached...
Replies (10)
Message 2 of 11
dbhunia
Hi
Your code should be like......(only modification .....)
Debashis Bhunia
Co-Founder of Geometrifying Trigonometry(C)
________________________________________________
Walking is the First step of Running, Technique comes Next....
Message 3 of 11
DC-MWA
When I tried yours I get message
"error: ActiveX Server returned the error: unknown name: "AREA""
this is because are is derived from doing the math on the two items "height" and "width".
;(setq Height (vlax-get obj 'Height))
;(setq Width (vlax-get obj 'Width))
(setq area (vlax-get obj 'Area))  <-- there is no "area' attached to aec windows.
Message 4 of 11
dbhunia
post drawing
or
Try with.....
(setq area (vlax-curve-getArea obj))
instead of.....
What is "aec windows"....????
Debashis Bhunia
Message 5 of 11
DC-MWA
The issue isn't getting the area. I have that figured out.
It's getting it to repeat as i select windows, then give me the total area when done selecting windows.
See the WINDOWAREA.lsp file (it works great on one window only)
See MULTIPLEWINDOWAREA.lsp (this is my attempt to get the program to repeat and add area as described above)
Message 6 of 11
dbhunia
Try this.....
(defun c:mwinarea ( / ent obj Height Width)
  (setq count 0)
  (setq Area-Total 0)
  (while (and (< count 100)
              (setq ent (entsel "Select aec doors and windows to get area from: "))
 	(setq obj (vlax-ename->vla-object (car ent)))
 	(setq area (* (vlax-get obj 'Width) (vlax-get obj 'Height))
 	(setq areasf (/ area 144))
        (print areasf)
        (setq Area-total (+ areasf Area-Total))
        (setq count (1+ count))
  ); end while
(princ (strcat "\nTotal Area:  " (vl-princ-to-string Area-total)))
(princ)
To check post a drawing......
Debashis Bhunia
Message 7 of 11
DC-MWA
I get error...
APPLOAD mwinarea.lsp successfully loaded.
Command: malformed list on input
Message 8 of 11
ronjonp
Missing parenthesis on this line:
(setq area (* (vlax-get obj 'width) (vlax-get obj 'height)))
Message 9 of 11
DC-MWA
It seems to work great. I will test on real life senecrio.
Thank you so very much!!
Message 10 of 11
ronjonp
I just made a small correction, @dbhunia should get the credit. 🙂
Message 11 of 11
ronjonp
Also why are you picking these one at a time? This would be very easy to modify so that you'd make one selection and get your tally. What doe this return when you pick a window: (print (cdr (assoc 0 (entget (car (entsel))))))
