How to trim by visual lisp
Message 1 of 14
Hello everyone
Just learning to use autocad & visual lisp for 1 week, and .. i have some question...
1.
    Where to find the command list guide:
 I've searched lots of website, but no one shows how to set the parameters.
for example:
   BOOL Rectangle(
   int x1,
   int y1,
   int x2,
   int y2
BOOL Rectangle(
   LPCRECT lpRect
2.
    I've made the line as below ("before"), and i need to change them to "after".
If use mouse click, it is very simple by "trim", but I have no idea about how to make this by visual lisp.
the code i am editing:  (seems fillet is not a good idea)
(command "mirror" objLineD2 "" pt2 pt3 "n")
(setq objLineD4(entlast))
(command "move" objLineD4 "" ptMove0 ptMove1) ;
(command ".copy" objLineD1 "" ptMove0 ptMoveLB)
(setq objLineDummy01(entlast))
(command ".copy" objLineNeck "" ptMove0 ptMoveLeft)
(setq objLineDummy02(entlast))
(command ".copy" objLineD2 "" ptMove0 ptMoveLT)
(setq objLineDummy03(entlast))
(setq ptDummy_L01(polar ptDummy_L00 (+ nTheta 0) 3) )
(setq ptDummy_L02(polar ptDummy_L00 (- (* pi 2) nTheta ) 3) )
(command "line" ptDummy_L00 ptDummy_L01 "")
(setq objLineDummy11(entlast))
(command ".copy" objLineDummy11 "" ptMove0 ptMoveLT)
(setq objLineDummy12(entlast))
(command "line" ptDummy_L00 ptDummy_L02 "")
(setq objLineDummy13(entlast))
(command ".copy" objLineDummy13 "" ptMove0 ptMoveRT)
(setq objLineDummy14(entlast))
(setq ptBound_L (list (car pLT) (- (cadr pLT) nPitch_Y)))
(command "line" pLT ptBound_L "")
(setq objLineBound_L(entlast))
(command "fillet" "r" 0)
(command "fillet" objLineDummy11 objLineDummy14)
(command "fillet" objLineDummy01 objLineBound_L)
(command "fillet" objLineDummy01 objLineDummy02)
(command "fillet" objLineDummy02 objLineDummy03)
(command "fillet" objLineDummy03 objLineBound_L)
Thank you.
Replies (13)
Message 2 of 14
ВeekeeCZ
Ok. First of all, this is a good place to start.
Your 1st point is not relevant to LISP.
Then - what is your "state before"? Is that some kind of export from some SW? Would be that always similar?
Post that example as dwg.
Message 3 of 14
Hi BeeKeeCZ,
Sorry, I'm not sure what is the "state before".
And the attachment are lsp file & dwg file.
Thank you.
Message 4 of 14
ВeekeeCZ
Ok, how about not trimming but make boundaries. See HERE how it works.
(defun c:LikeTrim (/ ss)
  (princ "\nObjects to be removed, ")
  (if (setq ss (ssget '((0 . "LINE"))))
    (progn
      (sssetfirst nil nil)
      (command-s "_.-BOUNDARY")
      (command "_.erase" ss "")))
  (princ))
Message 5 of 14
Thank you very much BeeKee CZ.
I'm trying to adding the code  into my .lsp file, got some problem.
1. replacing "select range" by ssDummy
2. but not sure how to input "mouse pt "x 3    by code.
; trying to select all lines into ssDummy
; how i input the mouse click point
(setq ssDummy(ssadd))
(ssadd objLineDummy01 ssDummy)
(ssadd objLineDummy02 ssDummy)
(ssadd objLineDummy03 ssDummy)
(ssadd objLineDummy11 ssDummy)
(ssadd objLineDummy12 ssDummy)
(ssadd objLineDummy13 ssDummy)
(ssadd objLineDummy14 ssDummy)
(LikeTrim ssDummy)
(defun LikeTrim ( ss)
(if (setq ss (obj)))
(progn
(princ))
Message 6 of 14
update my current code.
(setq ss ssDummy)
(LikeTrim ss )
(if ss
(progn
(command "_.erase" ssDummy "")
Message 7 of 14
dbhunia
first thing "objLineDummy*" must be "Entity name"..... like.....
(defun c:ss1 ()
(ssadd (setq objLineDummy1 (car(entsel))) ssDummy)
(ssadd (setq objLineDummy2 (car(entsel))) ssDummy)
(ssadd (setq objLineDummy3 (car(entsel))) ssDummy)
(ssadd (setq objLineDummy11 (car(entsel))) ssDummy)
(ssadd (setq objLineDummy12 (car(entsel))) ssDummy)
(ssadd (setq objLineDummy13 (car(entsel))) ssDummy)
(ssadd (setq objLineDummy14 (car(entsel))) ssDummy)
(ssadd (setq objLineDummy15 (car(entsel))) ssDummy)
(setq ss ssDummy)
(LikeTrim ss)
(if ss
   (progn
	;(sssetfirst nil nil)
Use "SS1" as a command you can understand......(This is only for the attached Drawing & as per your attached image)
Here "(setq objLineDummy* (car(entsel)))" is used only to get the "Entity name"...........
If your variables "objLineDummy*" containing "Entity name"........... then the syntax will be like.......
(ssadd objLineDummy* ssDummy)
instead of ......
But if your requirement is as per your attached image .......... then I think the solution of @ВeekeeCZ is best fit for you....
Debashis Bhunia
Co-Founder of Geometrifying Trigonometry(C)
________________________________________________
Walking is the First step of Running, Technique comes Next....
Message 8 of 14
ВeekeeCZ
How do you (want to) get all the objLineDummy** entities/objects?
Did you create them, over exporte them, you will select them? All at one / one by one...
Message 9 of 14
Hi BeeKee CZ
I've listed all of the obj i want to select, and it worked.
however, i don't know how to make " mouse click 3 times" in the code.
(as your video strat from 0:06)
https://knowledge.autodesk.com/community/screencast/c8d61d55-64b3-485c-9abc-b056d4931998
Thank you.
Message 10 of 14
ВeekeeCZ
@Anonymous wrote:
... however, i don't know how to make " mouse click 3 times" in the code....
Well, and how do you want to get those point? User Pick? Or calculated? The pick is quite simple. Just add as many PAUSE as you need:
(command "boundary" ss "" pause pause pause)
But if the later, that would be challenging for you. And impossible for me to answer - since you never answer any of my questions. So, just think about it, how would you calculate some inside points from entities you have - you don't need to be a programmer, it's just a geometry. If you tell me the algorithms, you'll help you to put it in the code.
Message 11 of 14
@ВeekeeCZ
Thank you for the reply always, it really helps me a lot.
Sorry for i didn't explained clearly.
On this project, I have to draw pattern array in a specify rectangle area.
>> i create them first then i will put them to the right place, and the last step is using array to copy them.
>> since it required 3 click point after using your solution, i calculated 3 point as below.
pt1.x = (A-B)/2
pt1.y = (L-2C)*1/4
pt2.x = (A-B)/2
pt2.y = (L-2C)*2/4
pt3.x = (A-B)/2
pt3.y = (L-2C)*3/4
for other lines and point, it's calculated by tan/sin/cos and polar in the code' first step as attachment.
Last but not the least, I still don't know how to automatically finish the last step of your solution.
I have to click pt1, pt2, pt3 by mouse then press "SPACE" by keyboard, then your solution worked perfectly.
(but I need it to be done automatically)
(defun LikeTrim (ss pt1 pt2 pt3)
(if ss
(progn
(command "erase" ss "" pt1 pt2 pt3 pause)
Message 12 of 14
Update lsp file again.~
Message 13 of 14
@ВeekeeCZ
Successed !!!
modified the code as below.
(if ss
(progn
(command-s "_.-BOUNDARY" pt1 "")
(command-s "_.-BOUNDARY" pt2 "")
(command-s "_.-BOUNDARY" pt3 "")
(command "erase" ss "")
);progn
);if
);defun
Thank you so much.
Message 14 of 14
ВeekeeCZ
Glad that you figured it out on your own!
BTW These things are sensitive about to be on the visible screen. Consider to ZOOM Extents before you run it.
