How to retrieve to text?
sarsivi30993
sarsivi30993
CONVERSION OF PDF TO DWG PRODUCES TEXT AS LINES. HOW TO RETRIEVE TO TEXT?
Dear All,
I convert pdf 2 cad using AutoCAD software (Import) option. PDF 2 CAD converted successfully all objects places. But, text is not text format its polyline format property panel saying. Conversion of pdf to dwg produces text as lines.I want text format. How to retrieve to text.
I attached sample pdf and converted drawing file.
Any shortcuts there. please tell me.
Thanks in advance.
ВeekeeCZ
I guess since ACAD 2018 there is a built-in tool for that, look HERE
See the attachment... just as the example, probably didn't convert it all.
sarsivi30993
thank you and this command is very useful @ВeekeeCZ
PDFSHXTEXT this command is useful only for individual selection.
If we select whole sheet only 50% is converted successfully, remaining item need to work as individual selection.
Is it possible to convert 100% text format?
ВeekeeCZ
Yes. I know. But the tool is quite good, so I can bed with you that I can convert all the texts within 2 mins. So take it or leave it. I can assure you that you won't receive any better tool than this one.
Only thing I would recommend you is to ask in the regular AutoCAD forum if there is some trick to integrate this into the converting process.
