Creating multiple closed polygons in selected closed boundaries
Message 1 of 14
Dear Helpers,
I stucked in creating lot of closed polygons in closed boudaries. Suppose we have so many rooms in a floor of a building with just lines and arcs. The lisp should generate multiple polygons inside the closed boundaries of rooms or zones.
Please have a look on attached drawing.
Replies (13)
Message 2 of 14
dbhunia
Hi
If your every Room is named then try this........(Chose a layer create Polyline & change its properties.....)
(defun C:CB (/)
(setvar "CMDECHO" 0)
(princ "\nSelect the Text/Mtext Inside the Closed Area: ")
(Setq selectionset (ssget '((0 . "*TEXT"))))
(repeat (setq N (sslength selectionset))
	(setq Data (ssname selectionset (setq N (- N 1))))
	(setq EntityData (entget Data))
	(setq IP_Text (cdr (assoc 10 EntityData)))
	(command "BOUNDARY" "_none" IP_Text "")
(setvar "CMDECHO" 1)
(princ)
Debashis Bhunia
Co-Founder of Geometrifying Trigonometry(C)
________________________________________________
Walking is the First step of Running, Technique comes Next....
Message 3 of 14
Exact Solution I got from you.
Very Nice. Thankin you So much. Perfectly suited to my task
Message 4 of 14
Thank you Very much.
But it's not working with without text. If some rooms may not having text inside. So in that case also it should create Room boundaries.
Thank you inadvance, Sir.
Message 5 of 14
dbhunia
chek this..... created by @ВeekeeCZ.....
https://forums.autodesk.com/t5/visual-lisp-autolisp-and-general/ssget-to-select-a-polyline-using-two...
And first give some clue how the problem can be solved.......
Second post your workout.......
Because its sure you are going to ask many questions 1 by 1.......
Debashis Bhunia
Message 6 of 14
phanaem
Try the attached lisp.
Works with lines, arcs, circles and polylines, parallel to UCS.
Message 7 of 14
I used the below code from that link. But couldn't work.
(defun c:testeclose ( / ss i obj pnt ptlst ptsum )
  (if (setq ss (ssget '((0 . "LWPOLYLINE") (-4 . "<NOT") (-4 . "&=") (70 . 1) (-4 . "NOT>") (-4 . ">") (90 . 2))))
    (repeat (setq i (sslength ss))
      (setq ptlst nil ptsum '(0 0)
	    ptlst (mapcar 'cdr (vl-remove-if-not '(lambda (x) (= (car x) 10))
				      (entget (ssname ss (setq i (1- i)))))))
      (foreach x ptlst (setq ptsum (mapcar '+ x ptsum)))
      (setq pnt (mapcar '/ ptsum (list (length ptlst) (length ptlst))))
      (if pnt (command "_.-boundary" "_non" pnt ""))))
  (princ)
Message 8 of 14
Thank you So much Sir. It's working fetatstic
Message 9 of 14
alansanudo
What's the command how can i execute it? will it work to create multiple boundaries for different "areas" as the image attached?
windows 7, intel I7, 8 MB RAM, civil3d 2013.
Message 10 of 14
Kent1Cooper
Here's a way to do that.  It asks you to pick points [just on-screen -- nothing drawn] defining opposite corners of a rectangular area that completely encloses the drawn [I assume property-line] parcels, and asks for a spacing increment, starts a BOUNDARY command, and just picks every point in a grid at that spacing throughout the area.  If it picks outboard of it all, a message goes by that no enclosed area was found, and if it picks more than once within the same area, a message goes by that the area has already been picked, but in either case it doesn't bother anything -- it keeps going.  Give it a spacing increment small enough that it's bound to land inside every parcel somewhere at least once, maybe a little less than the smallest parcel edge expected.  You will want to turn off Layers other than those of your property lines, so that it won't find an enclosed area outside of them all.  And it depends on all the parcels really being closed.  Minimally tested.
(defun C:MBound ; = Multiple Boundaries
  (/ cor1 cor2 UR rowleft pt)
  (setq
    cor1 (getpoint "\nOne corner of area-enclosing rectangle: ")
    cor2 (getcorner cor1 "\nOpposite corner: ")
    inc (getdist "\nPick-point spacing increment: ")
    UR (mapcar 'max cor1 cor2)
    rowleft (mapcar '+ (mapcar 'min cor1 cor2) (list inc inc))
    pt rowleft
  ); setq
  (command "_.boundary" "advanced" "object" "Polyline" "")
  (while (< (cadr pt) (cadr UR)); still below top edge
    (while (< (car pt) (car UR)); still to left of right edge
      (command pt)
      (setq pt (polar pt 0 inc))
    ); while
    (setq
      rowleft (polar rowleft (/ pi 2) inc)
      pt rowleft
    ); setq
  ); while
  (command "")
  (princ)
); defun
Kent Cooper, AIA
Message 11 of 14
alansanudo
Thanks for the explanation, but how do I execute the code? sorry for my ignorance.
Message 12 of 14
Kent1Cooper
Copy the code into a plain-text editor such as Notepad.  Save it to a file with a .LSP filetype ending [call it anything you want].  In AutoCAD, APPLOAD that file.  The command name is MBound [the part immediately following C: -- not case-sensitive].
Kent Cooper, AIA
Message 13 of 14
kareemelnady8
"Enclosed polylines v1.03.lsp" this is perfect it's very good thank you
Message 14 of 14
albinZ5N68
Hi, thanks for your work.
I'm trying to adapt it to get the result shown in the attachment (automatic separation of closed parts, with inclusion of objects inside the parts).
But already, when I use the LISP on my entire drawing, if I have multiple separate elements, the region detection gives me full regions instead of only the smallest ones... Do you know why?
