I'm trying to create a 3DPoly, but every time it draws it, it's only 2D. Is there a setting I'm missing? There is probably a simple answer, but I can't find it.
newPntList = ((-4.45 -3.511 0.29) (-4.2 -3.511 0) (-4.2 -3.765 0) (-4.45 -3.765 0.29))
I tried:
(apply 'command
(append
'(".3dpoly")
newPntList
I even tried:
(setq pnt1 (nth 0 newPntList)
pnt2 (nth 1 newPntList)
pnt3 (nth 2 newPntList)
pnt4 (nth 3 newPntList))
(command "3dpoly" pnt1 pnt2 pnt3 pnt4 "cl" "")
They both create a 2D polyline and disregard the Z from the list.
Can anyone shed some light on this?
Solved by Kent1Cooper. Go to Solution.
Worked in Bricscad added "C" so it closes. Tried osnapz 0 or 1 did not make any difference, but ID will show z=0 depending on osnapz but a list of the pline shows Z=0.29.
[I guess OSNAPZ is irrelevant, if it really only affects points returned by Osnapping.]
Both methods work for me, in 3D. [The second one has an extraneous "" at the end -- not needed, because the close option finishes the command.]
Do you perhaps have some running Object snap mode(s) on and any other stuff drawn in the vicinity that it might be Osnapping to?
@mgorecki wrote:I'm trying to create a 3DPoly, but every time it draws it, it's only 2D. Is there a setting I'm missing? There is probably a simple answer...
there always is and free of heck commands
(setq newPntList '((-4.45 -3.511 0.29) (-4.2 -3.511 0) (-4.2 -3.765 0) (-4.45 -3.765 0.29))
newPntList (apply 'append newPntList)
3d_poly (vla-add3dpoly (vla-get-block (vla-get-activelayout (vla-get-activedocument (vlax-get-acad-object))))
(vlax-safearray-fill (vlax-make-safearray
vlax-vbdouble
(cons 1 (length newPntList))
newPntList
I've used the following successfully.
(command "_3dpoly" )
(while (= (getvar "cmdactive") 1)
(repeat
(setq x (length pntList))
(command "_non" (nth (setq x (- x 1)) pntList))
) ;end repeat
(command "") ;end 3dpoly
) ; end while
I have a command when the code first starts that turns off all of the osnaps. I thought it was off, I must have turned it on to test something and I forgot. Yep, I feel stupid.
