Trying to Create a 3DPOLY from a List
mgorecki
mgorecki
I'm trying to create a 3DPoly, but every time it draws it, it's only 2D.  Is there a setting I'm missing?  There is probably a simple answer, but I can't find it.
newPntList = ((-4.45 -3.511 0.29) (-4.2 -3.511 0) (-4.2 -3.765 0) (-4.45 -3.765 0.29))
I tried:
(apply 'command
 (append
  '(".3dpoly")
  newPntList
I even tried:
(setq pnt1 (nth 0 newPntList)
      pnt2 (nth 1 newPntList)
      pnt3 (nth 2 newPntList)
      pnt4 (nth 3 newPntList))
(command "3dpoly" pnt1 pnt2 pnt3 pnt4 "cl" "")
They both create a 2D polyline and disregard the Z from the list.
Can anyone shed some light on this?
Replies (9)
Kent1Cooper
What is your setting for the OSNAPZ System Variable?
Kent Cooper, AIA
Sea-Haven
Worked in Bricscad added "C" so it closes. Tried osnapz 0 or 1 did not make any difference, but ID will show z=0 depending on osnapz but a list of the pline shows Z=0.29.
Kent1Cooper
[I guess OSNAPZ is irrelevant, if it really only affects points returned by Osnapping.]
Both methods work for me, in 3D.  [The second one has an extraneous "" at the end -- not needed, because the close option finishes the command.]
Do you perhaps have some running Object snap mode(s) on and any other stuff drawn in the vicinity that it might be Osnapping to?
Kent Cooper, AIA
komondormrex
@mgorecki wrote:
I'm trying to create a 3DPoly, but every time it draws it, it's only 2D.  Is there a setting I'm missing?  There is probably a simple answer...
there always is and free of heck commands
(setq newPntList '((-4.45 -3.511 0.29) (-4.2 -3.511 0) (-4.2 -3.765 0) (-4.45 -3.765 0.29))
	  newPntList (apply 'append newPntList)
	  3d_poly (vla-add3dpoly (vla-get-block (vla-get-activelayout (vla-get-activedocument (vlax-get-acad-object))))
							 (vlax-safearray-fill (vlax-make-safearray
							 							vlax-vbdouble
												 		(cons 1 (length newPntList))
												  newPntList
leeminardi
I've used the following successfully.
(command "_3dpoly" )
(while (= (getvar "cmdactive") 1)
(repeat
(setq x (length pntList))
(command "_non" (nth (setq x (- x 1)) pntList))
)					;end repeat
(command "")			;end 3dpoly
) 					; end while
lee.minardi
mgorecki
I have a command when the code first starts that turns off all of the osnaps. I thought it was off, I must have turned it on to test something and I forgot.  Yep, I feel stupid.
mgorecki
Thanks for the input, yes, I'll add the "c" to close it off.
mgorecki
Thank you for the code.
mgorecki
Thanks for taking the time to respond.
