tricky autolisp copy rutine
Hello. I lost an old lisp database that a friend once gave me and I'm trying to reconstruct it.
The routine was something like this (I don't know how to write it properly, though):
(defun c:CII ()
(Prompt "Copy from intersection to intersection point");inform user
(princ "\nSelect objects to copy")
(setq copy_objects (ssget));;; (first question, if I press enter after not selecting anything, I want to select the previos selected set)
(command "copy" copy_objects "" "m" "int" pause (getvar "osmode") (setvar "osmode" 32);(here I don't want the command to execute if I don't hit the exact intersection point and prompt the error if it happens); (setvar "osmode"); this will set the osmode to its status before the command (after the routine it's actually ended).
I'm very confused to make this work, I have only made it by pieces and, when I do something right, it is only to mess up another part.
I hope somebody can help me.
Thank you so much
roland.r71
Something like this?
(defun c:CII ( / osmode pt ss)
   ; *copy_objects* : Global var to remember selected objects
   (prompt "\nCopy from intersection to intersection point\n") ; inform user
(setq ss (ssget)) ; Select objects (setq *copy_objects* (cond (ss)(*copy_objects*))) ; if non use previous (if *copy_objects* ; check if anything selected
(progn
(if (not ss)(sssetfirst nil *copy_objects*)) ; Highlight (previous) selection (setq osmode (getvar "osmode")) ; Store osmode setting
(setvar "osmode" 32) (setq pt (getpoint "Select intersection point")) ; Get intersection point (if (not pt) (princ "\nNo point selected") ; Warn: no point ; else
(command "_.copy" *copy_objects* "" "m" "int" pt) ; Copy objects using point ) (setvar "osmode" osmode) ; Restore original osmode ) ) )
ВeekeeCZ
Little different version from @roland.r71's, especially the copy part.
(defun c:CII ( / *error* osm ss)
  (defun *error* (errmsg) ;; just in case you hit ESC to exit the copy command to return origin osmode
    (if (not (wcmatch errmsg "Function cancelled,quit / exit abort,console break,end"))
      (princ (strcat "\nError: " errmsg)))
    (setvar 'osmode osm))
  (prompt "\nCopy from intersection to intersection point")
  (princ "\nSelect objects <previous selection>: ")
  (setq osm (getvar 'osmode))
  (setvar 'osmode 32)
  (if (setq ss (cond ((ssget))
                     ((ssget "_p"))))
    (command-s "_.copy" ss "" "_m"))
  (princ)
roland.r71
The error trap is a must have adition in this case, which I forgot to add.  Smiley Sad
Messing up snap settings in case of ESC should of course be prevented
Thank you so much. I'll try it and let you know how it went
Got it, you guys have been very helpful. Thanks
