Two Commands to be Run Individually on each piece of Mtext In a Drawing
Hi all,
You may want to disregard the title as I really didn't know how to describe what I'm trying to do with one sentence haha. What I need is a macro, lisp, or recorded action that will let me run through a set of Mtext objects and run two different already created lisp routines on each piece of Mtext that is on a certain layer. Basically it would do this:
1) Run a lisp routine titled: "Fiber-TilePhoto1"
2) Select text "228 477" on layer "B-TILE-NUMB"
3) Once that has completed, run lisp routine "Fiber-TilePhoto2"
4) The macro or lisp would then go to the next piece of mtext on layer "B-TILE-NUMB" and repeat steps 1 thru 3.
5) This macro would run on every piece of mtext on the mentioned layer that exists in the drawing.
Is this possible?
Thanks!
*AutoCAD Map 3D 2019 64 bit on Windows 10*
roland.r71
@Anonymous wrote:
Hi all,
Is this possible?
Thanks!
Hmmm, it sounds a bit confusing, so... you want 2 lisp routines to be run on each MTEXT on layer "B-TILE-NUMB" (?)
- Select all MTEXT on layer "B-TILE-NUMB"
- for each text
- Run the lisp routine "Fiber-TilePhoto1"
Q: Is the function written to take an active selection? or do you need to supply one as argument? or does it take only a single MTEXT and it needs to be repeated for all?
- Then Run lisp routine "Fiber-TilePhoto2"
It should be possible, but how depends on a few things. Mostly on how those other 2 routines work.
Could you share a sample dwg (in a regular old acad format most (incl. me) can read) & the two lisp routines?
Q1 Answer: The lisp will only allow selection of a single mtext string. Basically when you select a certain number which is a label for a "tile", the lisp runs a 3rd party application that goes and grabs a geo-located Google Maps image for the area that the tile represents. It then screen-grabs/cuts the image and references it in that "tile". You do this for all the tile numbers: 228-477, 229-478, 230-478, etc. Once completed, you are left with a mosaic of hundreds of images that make up an overall map area.
Q2 Answer: This lisp automatically runs on the image that was placed from the first lisp. Its function is to rename and relatively path the image as a reference.
I am just trying to get out of having to run these two commands manually on each tile number in a given map.
To your last question, I don't think I could share the lisp routines as they are proprietary to the company I work for. I was just wondering (ignorantly) if there was a way to do this that would be agnostic to which two commands are actually being run. The macro would just run lisp 1, select tile number, run lisp 2 and repeat.
Thanks for your reply and sorry if this is confusing.
roland.r71
Ok, that makes it virtually impossible.
If the lisp works on its own and allows you to select a single entity, you can not use another lisp to select all mtext and feed them 1 by 1 to the first lisp. You'll need to rewrite (part off) that first lisp, to accept a supplied entity (instead of selecting one)
A similar problem might arise with the second lisp. (depending on how it "knows" what image was just placed and needs processing)
Thank you. I'll have to talk to my boss about altering the lisp.
