thaw all layers with New VP Freeze
dtiemeyer
Advisor Advisor
dtiemeyer
There are 2 commands that when typed in manually, seem to change all layers in the drawing which have 'New VP Freeze' set to 'Freeze', these commands change them to 'Thawed' which is what I want.
I've tried the following four items (separately) in my master LISP routine, and each reports back 'Unknown Command' when run via lisp.  HELP!
(command "._THAWALLNEWVPFREEZE")
(command "THAWALLNEWVPFREEZE")
(command "._NEWVPFREEZE")
(command "NEWVPFREEZE")
My other CAD is a Cadillac and I like to Revit to the Max!
scot-65
Assuming there is a custom LISP program where the opening line reads:
"(defun c:NEWVPFREEZE..."
This is not a native AutoCAD command and is invoked this way
(c:NEWVPFREEZE) from within another LISP routine.
Macro line inside the CUI as well as the keyboard is the "manual" way.
Scot-65
A gift of extraordinary Common Sense does not require an Acronym Suffix to be added to my given name.
dtiemeyer
actually using  (c:NEWVPFREEZE) was the answer I was needed. Cheers!
