text total
text total
k005
Advisor Advisor
Message 1 of 11
text total
k005
Hello
How can I get the sum of the values I gave in the sample drawing?
I colored the objects. to be descriptive. But I will make the selection manually...
Thanks in advance
Replies (10)
Message 2 of 11
rkmcswain
  • Use (ssget) to grab a selection from the user (or Automatic if you can filter on one or more properties)
  • Iterate that selection, and in your example, I'd search for the ":" and the "m" and grab the value in between and add that value to a variable.
  • At the end of the loop, that variable should be your total.
Message 3 of 11
hak_vz
Try this
(defun c:total ( / *error* string_to_list ss total ent e i)
(defun *error* ( msg )
		(if (not (member msg '("Function cancelled" "quit / exit abort")))
			(princ)
	(defun string_to_list ( str del / pos )
		(if (setq pos (vl-string-search del str))
			(cons (substr str 1 pos) (string_to_list (substr str (+ pos 1 (strlen del))) del))
			(list str)
	(setq del (getstring "\nSelect text specific delimiter (: = )  > " ))
	(princ "\nSelect text to add up > ")
	(setq ss (ssget '((0 . "TEXT"))) i -1)
	(setq total 0.0)
	(cond
		((and ss)
			(while (< (setq i (1+ i)) (sslength ss))
				(setq ent (entget(ssname ss i)))
				(setq e (cdr (assoc 1 ent)))
				(setq e (cadr (string_to_list e del)))
				(setq total (+ total (atof(cadr (string_to_list e " ")))))
	(princ (strcat "\nTotal sum is " (rtos total 2 2)))
	(princ)
Assure to have one " " in front and behind  delimiter i.e. " : " or " = ".  Write yourself a note in your lisp file
to remember this
;this is how to  write comment in autolisp  (start each  line with 😉
Miljenko Hatlak
Message 4 of 11
k005
@hak_vz
(setq e (cadr (string_to_list e ":")))
It was nice. Can we just include = in this code?
like xxxxxxspace=spacexxx m³
Message 5 of 11
hak_vz
@k005  My previous code is updated so try it now. I would have to add some additional string trimmings to remove spaces but this way you'll have consistent texts in your drawings.
Miljenko Hatlak
Message 6 of 11
3wood
You can also try ALTEXT.
The number sum is shown at the bottom of the dialogue box.
Message 7 of 11
k005
@hak_vz
" : " and " = " I won't enter it manually. The Lisp routine should be able to select this automatically... that's what I meant.
* It is very nice as it is.
Message 8 of 11
hak_vz
@k005 wrote:
@hak_vz
That way you can have any expression of type (description delimiter value unit) processed, but ok, here is the way you wish.
			(princ)
			(list str)
	(setq total 0.0)
	(cond
		((and ss)
				(if (vl-string-position (ascii ":") e) (setq del ":")(setq del "="))
	(princ)
Miljenko Hatlak
Message 9 of 11
k005
@hak_vz
again a very good solution.
Thanks a lot, it's ok. 🤗
Message 10 of 11
pbejse
(Defun c:Totally ( / Text ss pt i ent data a str b p m3 v pref m2_Coll)
;;		pBe Jul 2021		;;;
(defun Text (l pt str)
  (entmakex (append l
	      (list (cons 10 pt)
		    (cons 1 str)
(if (and
      (setq ss (ssget '((0 . "TEXT")(1 . "*:*m²,*=*m³"))))
      (setq pt (Getpoint "\nPick Text insertion point"))
  (progn
    (repeat (setq i (sslength ss))
      (setq ent (entget (ssname ss (setq i (1- i)))))
	(setq data (Cons
		     (mapcar '(lambda (d)
			      (assoc d ent)) '(1 0 7 8 40 50)) data))
	(while (setq a (car data))
	  	(setq str (cdar a) b (Cdr data))
		(cond
		  ((setq p (vl-string-position 61 str))
		   	(setq m3 (cons (read (substr str (+ 2 p))) m3))
		   	(foreach c (vl-remove-if-not '(lambda (d)
						(vl-string-position 61 (Cdar d))) b)
			  	(setq m3 (cons (read (substr (Cdar c) (+ 2 (vl-string-position 61 (Cdar c))))) m3 )
				      b (vl-remove c b)))
		   	(setq m3 (list
				   ( strcat  "Beton = " (rtos (apply '+ m3) 2 2) " m³")
				       (cdr a)))
		  ((setq p (vl-string-position 58 str))
		    (setq v (cons (read (substr str (+ 2 p))) v))
		    (setq pref (substr str 1 (1+ p)))
		     (foreach itm b
		       (if (= (vl-string-mismatch pref (cdar itm))  (1+ p))
		   	(setq v (cons  (read (substr (cdar itm) (+ 2 p))) v) b
			       (vl-remove itm b))
		   (setq m2_Coll (cons (list
					 (strcat  pref " " (rtos (apply '+ v) 2 2) " m²")
					     (cdr a)) m2_Coll) v nil)
		  (setq data b)
	  (foreach val m2_Coll
	    (Text (cadr val) pt (car val))
	    	(setq pt (polar pt (/ pi 2.0)
				(* (cdr (cadddr (cadr val))) 1.666))))
	(and m3 (Text (cadr m3) pt (car m3)))
  (princ)
Command: Totally
HTH
Message 11 of 11
k005
@pbejse
Thank you very much for the work.
Alternatively, I save it to my archive.
thanks my friend.
