check mark
check mark
k005
Advisor Advisor
check mark
k005
Hello
How can I print the checkmark as text when I click on a point?
* as layer : It should be "ONAY" and it should be color number 100.
* font style name "onay" font : windings , sign : ü
sign height : textsize * 2
I attached the file.
pbejse
You have a choice of three Marks here
Better yet,  take all of them.
k005
@pbejse
none
pbejse
@k005 wrote:
none
Oh Bummer, I was so sure you will at least pick one of the three 😊
k005
@pbejse
well then. my choice: Mark Wahlberg
and Max Payne
hak_vz
@k005 wrote:
@pbejse
and Max Payne
Marky Mark is not of help. Try this instead.
(defun c:checkmark ( / pt *error* oldstyle)
	(defun *error* ()
		(setq oldstyle (getvar 'Textstyle))
		(princ)
	(setvar 'Textstyle "Onay")
	(while (setq pt (getpoint "\nSelect check mark point >"))
		(entmake
			(list
				(cons 0 "TEXT")
				(cons 8 "Onay")
				(cons 100 "AcDbText")
				(cons 10 (trans pt 1 (trans '(0 0 1) 1 0 T)))
				(cons 40 (* 2 (getvar 'Textsize)))
				(cons 1 "\U+00FC")
				(cons 7 "Onay")
				(cons 62 100)
				(cons 50(angle '(0 0 0) (trans (getvar "UCSXDIR") 0 (trans '(0 0 1) 1 0 T))))
				(cons 210 (trans '(0 0 1) 1 0 T))
(setvar 'Textstyle oldstyle)
(princ)
Miljenko Hatlak
k005
@hak_vz
too many arguments
sorry.!  Thank you very much, it's ok. 🤗
