Lisp to create a MLine Style using parallel polylines as reference
aitorm
aitorm
Hi there!
I need to create several MLine styles and I find that it is very slow to create them. I was guessing if it would be possible to create a LISP that uses some lines I previously drew for reference to create a new MLine. For example, LISP that reads the polyline linetype and color and its offset distance from a base one and then creates a MLine Style that copies that info.
¿Do anyone knows how to do it?
Sea-Haven
Have a look at this, depending on what your measuring I use a drag over method pick 2 points and use a ssget "F" so get two objects can then do a VL  intersectwith for 1st point, then a VL closestpointto so distance pt1 pt2 is the offset.
Replace in the while below. using "F" Fence can do multiple parallel lines in one go.
; make mline
; By alan H oct 2020
; Set to bylayer at moment
; Thanks to FIXO for original code
(defun c:makml ( / lst1 lst2 lst desc MLINE_STYLE_NAME )
(setq 	MLINE_STYLE_NAME (getstring "\nEnter mline name ")
		desc (getstring "\nEnter description ")
(while (setq off (getreal "\Enter offset Enter to finish " ))
	(setq lst (cons off lst))
(if (= desc nil)(setq desc MLINE_STYLE_NAME))
(setq lst1
	(list '(0 . "MLINESTYLE")
		'(100 . "AcDbMlineStyle")
		(cons 2 MLINE_STYLE_NAME)
		'(70 . 0)
		(cons 3 desc)
		'(62 . 256)
		'(51 . 1.5708)
		'(52 . 1.5708)
		'(71 . 4)
(setq x (length lst))
(repeat x
	(setq lst2 (list
		(cons 49 (nth (setq x (- x 1)) lst))
		(cons 62 256)
		(cons 6 "BYLAYER")
	(setq lst1 (append lst1 lst2))
(if
	(not (dictadd
		(cdar (dictsearch (namedobjdict) "ACAD_MLINESTYLE"))
		MLINE_STYLE_NAME
		(entmakex lst1)
	(Alert "Impossible to create mline style\n perhaps this was exist earlier")
(setvar 'cmlstyle MLINE_STYLE_NAME)
(princ)
(c:makml)
aitorm
This code is very helpful and make me rethink what I want. Just choosing the distances from the command line works for me, so the only think I would need to do is to be able to choose also the belonging linetypes.
But I have no idea how to face this. Can anyone help me?
Sea-Haven
Its a command called MLSTYLE.
