Notice: Upload of PDF documents is currently unavailable across the Community due to an ongoing issue.
Text string to a field IF/THEN condition
PauloMiranda8553
Message 1 of 13
PauloMiranda8553
I need some help here, I'm trying to set a text string to a field that read a 2 characters from the file name. Kinda of read characters 12 and 13, and if content is RD, the value should be RED, if YL, Yellow, GR - Green, and so on. I have 5 or 6 possible values.
The file name is like: X-25-034-A-PE-PGR-.dwg
I alread set this, but always get a  "$(IF,??) " error:
$(IF,$(=$(substr,$(getvar,dwgname),12,2)RD),"RED")
The IF/THEN is correct?
Can a text string be assigned to the field? Is this the way?
Help will be very apreciated.
Thanks to all.
Paulo Miranda
Replies (12)
Message 2 of 13
Brock_Olly
From chatGPT:
You're on the right track, but the issue comes from how the string comparison is done in AutoCAD fields. The $(IF) function expects a specific format, and the way you're trying to compare the substring isn't quite right.
Here's an improved version of your field expression:
$(IF,$(=,$(substr,$(getvar,dwgname),12,2),RD),RED, $(IF,$(=,$(substr,$(getvar,dwgname),12,2),YL),Yellow, $(IF,$(=,$(substr,$(getvar,dwgname),12,2),GR),Green, Other)))
Explanation:
  • $(substr,$(getvar,dwgname),12,2) gets the substring starting from the 12th character and extracts 2 characters.
  • $(=, ...) compares the extracted substring to a specific value (e.g., RD, YL, GR).
  • $(IF, ...) checks if the condition is true. If it is, it returns the first value (e.g., RED). If it's false, it checks the next condition.
  • I've added an Other value at the end for any unmatched cases.
This expression should work, provided the file name is correct and consistent with your pattern. It will check for RD, YL, and GR, and return the corresponding color name.
Message 3 of 13
PauloMiranda8553
Thanks for your reply.
The expression don't work, keep the same "$(IF,??) " error.
Now there's something I found... if I replace alphabetic (e.g., RED) for a numeric value (e.g., 01), it works...
So, the problem is there... extracted substring alphabetic/numeric comparation...
Any clue?
Message 4 of 13
paullimapa
Make any difference if surround the characters with quotes?
$(IF,$(=,$(substr,$(getvar,dwgname),12,2),"RD"),"RED")
Paul Li
IT Specialist
@The Office
Message 5 of 13
Brock_Olly
If Pauls doesn't work, does this work?
$(IF,$(=,$(substr,$(getvar,dwgname),12,2),RD),"RED",$(IF,$(=,$(substr,$(getvar,dwgname),12,2),YL),"Yellow",$(IF,$(=,$(substr,$(getvar,dwgname),12,2),GR),"Green","Other"))))
Message 6 of 13
PauloMiranda8553
Nope... 😢😢
Message 7 of 13
PauloMiranda8553
No, either way...
So strange...
Message 8 of 13
Brock_Olly
Workaround Approach
  1. Create a field to extract the substring (store it in a hidden attribute or text field):
    • This extracts the 12th and 13th characters from the drawing name.
  2. Reference that extracted value in a second field for conditional logic:
    $(IF,$(=,$(substr,$(getvar,dwgname),12,2),"RD"),"RED",
    $(IF,$(=,$(substr,$(getvar,dwgname),12,2),"YL"),"YELLOW",
    $(IF,$(=,$(substr,$(getvar,dwgname),12,2),"GR"),"GREEN","OTHER"))))
    • Important: Ensure that "RD", "YL", and "GR" are explicitly treated as strings.
    • If AutoCAD still refuses to recognize it, try inserting the substring field into an attribute or MTEXT first, then referencing it in the condition.
Message 9 of 13
Brock_Olly
I'm kind of going in the dark here so if you could upload your DWG or a sample with the field so we can test it out too that'd be nice.
Message 10 of 13
PauloMiranda8553
Thank you  my friends, nothing work.
I attached my sample...
The field should read from the file name... but only in the numeric characteres it work.
Thanks.
Message 11 of 13
paullimapa
I wonder perhaps the problem is with using = since that’s for number comparisons. Maybe try eq instead since that’s for string comparisons
https://help.autodesk.com/view/ACDLT/2025/ENU/?guid=GUID-F94A885A-4DA2-432B-AC1A-EB49CC6C1C72
Paul Li
IT Specialist
@The Office
Message 12 of 13
PauloMiranda8553
That's the problem...
You made it.
Thank you very much... Appreciate that.
Message 13 of 13
paullimapa
It was a group effort…cheers!!!
Paul Li
IT Specialist
@The Office
