Required a Macro For select by text alignment y
sdhara.hit
sdhara.hit
Supposed I have many text with same y alignment. Now I want a macro like I will select 1 text, and it will select all text which have same y alignment .
  • VBA
Brock_Olly
Try this LISP:
You can adjust the value '0.0001' on line 26 to increase the sensitivity. (set it to 5 and it will select any text within 5 Y-units of selection)
(if (equal y2 x-coord 0.0001)
(defun c:SelectByYAlignment ()
  (setq ent (car (entsel "\nSelect a text object: ")))
  (if (and ent (or (eq (cdr (assoc 0 (entget ent))) "TEXT")
                    (eq (cdr (assoc 0 (entget ent))) "MTEXT")))
    (progn
      ;; Extract coordinate of selected text
      (setq entData (entget ent))
      (setq y-coord (car (cdr (assoc 10 entData))))
      (if (null y-coord)
          (setq y-coord (car (cdr (assoc 11 entData)))))
      ;; Select all text objects in the drawing
      (setq ss (ssget "X" '((0 . "TEXT,MTEXT"))))
      (setq selSet (ssadd))
      (if ss
        (progn
          (setq i 0)
          (repeat (sslength ss)
            (setq ent2 (ssname ss i))
            (setq entData2 (entget ent2))
            (setq y2 (car (cdr (assoc 10 entData2))))
            (if (null y2)
                (setq y2 (car (cdr (assoc 11 entData2)))))
            ;; Compare only X-coordinates, ignore Y
            (if (equal y2 y-coord 0.0001)
              (ssadd ent2 selSet))
            (setq i (1+ i))))
        (princ "\nNo matching text found."))
      ;; Highlight selected objects
      (if (> (sslength selSet) 0)
        (sssetfirst nil selSet)
        (princ "\nNo text objects found with the same Y-coordinate."))
    (princ "\nSelected object is not a TEXT or MTEXT."))
  (princ))
sdhara.hit
@Brock_Olly , Thanks , But its select the text which have same x valu. I required Same y value.  I have attached result after after applying your LSP. Can you please provides which select same y value ?
Brock_Olly
Here's a swapped version:
I was confused and swapped Y and Vertical around my bad.
    (progn
      (setq y-coord (cadr (cdr (assoc 10 entData))))
      (if (null y-coord)
          (setq y-coord (cadr (cdr (assoc 11 entData)))))
      (setq i 0 selSet (ssadd))
      (if ss
          (setq y2 (cadr (cdr (assoc 10 entData2))))
          (if (null y2)
              (setq y2 (cadr (cdr (assoc 11 entData2)))))
          (if (equal y2 y-coord 0.0001)  ;; Ensure Y comparison with tolerance
          (setq i (1+ i)))
  (princ))
sdhara.hit
Thanks a lot. This is exact which I want. Love You.
