- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
When using Field, in the objects and formula category, selecting a table cell to pull the information, I am facing a small problem. When this cell is a number, the function works perfectly, however, when the cell contains some different character or any simple text (which is not a number, just a letter), the command does not show anything in the Field, just the # showing contain an error. I would like help to solve this problem, because I understand that pulling a text and a number should be the same thing. For my use, I necessarily need the field to pull a text from a table cell, so if there is any other way to do this, I accept the suggestion as well.
