Text Area calculation
k005
Advisor Advisor
Message 1 of 41
k005
How can I print the area of the text objects (**x**) in the texts I have given in the example?
Existing list ( text object)
PZ01 (150/25)
SZ12 (60/40)
PZ03 (180/30)
wanted list
0.375 m²
0.24 m²
0.54 m²
SZ01 (30/60)
SZ04 (60/35)
SZ02 (35/60)
SZ03 (30/60)
SZ06 (40/70)
SZ05 (60/40)
PZ02 (255/25)
SZ08 (80/30)
SZ07 (60/30)
SZ11 (60/30)
SZ10 (40/60)
SZ13 (40/90)
SZ09 (40/65)
SZ16 (40/60)
SZ17 (40/60)
SZ15 (40/60)
SZ14 (30/60)
PZ05 (25/180)
PZ04 (25/150)
PZ01 (150/25)
SZ12 (60/40)
PZ03 (180/30)
Accepted solutions (3)
Replies (40)
Message 21 of 41
hak_vz
I guess this is what you asked for.
(defun c:repl (/ *error* adoc  string_to_list ss e ent i nt)
	(defun *error* ( msg )
		(if (not (member msg '("Function cancelled" "quit / exit abort")))
			(princ)
		(if (and adoc) (vla-endundomark adoc))
		(princ)
	(defun string_to_list ( str del / pos )
		(if (setq pos (vl-string-search del str))
			(cons (substr str 1 pos) (string_to_list (substr str (+ pos 1 (strlen del))) del))
			(list str)
	(princ "\nSelect text to change with area >")
	(setq adoc (vla-get-activedocument (vlax-get-acad-object)))
	(setq ss (ssget '((0 . "TEXT"))) i -1)
	(vla-startundomark adoc)
	(while (< (setq i (1+ i)) (sslength ss))
		(setq ent (entget(ssname ss i)))
		(setq e (cdr (assoc 1 ent)))
		(setq e (substr e (+(vl-string-position  (ascii "(") e) 2)))
		(setq e (substr e 1 (- (strlen e)1)))
		(setq e (string_to_list e "/"))
		(setq e (mapcar 'atof e))
		(setq nt(strcat "("(rtos (/ (* (car e)(cadr e)) 10000.0) 2 3) " \U+33A1" ")"))
		(setq ent (subst (cons 1 nt)(assoc 1 ent) ent))
		(entmod ent)
	(princ "\nDone!")
	(princ)
It's time to switch to Euro 2020 Ukraine ws England.
Miljenko Hatlak
Message 22 of 41
k005
@hak_vz
Thank you very much. Yes.! Super!
Message 23 of 41
pbejse
@k005 wrote:
we will just create new TEXT. the format is just this: 0.18 m²
Here you go
(Defun c:TrueSize ( / _WantedList)
(defun _WantedList (str / p )
      (setq p (vl-string-position 40 str))
        (strcat "(" (rtos (apply '*
		(cons  0.0001
		  (read (Vl-string-subst " " "/" (substr str (1+ p)))) )
	      		) 2 3 ) " m²)")
  (if (setq ss (ssget "_:L" '((0 . "TEXT")(1 . "*(*#/#*)"))))
    (repeat (setq i (sslength ss))
      (setq str (getpropertyvalue (setq e (ssname ss (setq i (1- i)))) "TextString"))
      (setq new_str (_WantedList str))
      (setpropertyvalue e "TextString" new_str)
    )(princ)
HTH
Message 24 of 41
3wood
You can also try ALTEXT.
Use following codes in ALTEXT as a formula.
;;; This is an example formula for ALTEXT.vlx
;;; It convert text in a format of "(36/60)" to "0.18m2"
(defun ALTEXT_FORMULA (/ P1 P2 P3 T0 T1 T2)
  (setq P1 (vl-string-search "(" ALTEXT_STR_ORG) ;(setq ALTEXT_STR_ORG "SZ01 (60/40)")
	P2 (vl-string-search "/" ALTEXT_STR_ORG)
	P3 (vl-string-search ")" ALTEXT_STR_ORG)
	T0 (substr ALTEXT_STR_ORG 1 P1)
	T1 (substr ALTEXT_STR_ORG (+ P1 2) (- P2 P1 1))
	T2 (substr ALTEXT_STR_ORG (+ P2 2) (- P3 P2 1))
   (if (and T0 T1 T2)
     (strcat T0 "(" (vl-string-right-trim "0" (rtos (/ (* (atoi T1) (atoi T2)) 10000.0) 2)) "m\U+00B2)")
Result drawing as in the attachment.
Message 25 of 41
k005
@3wood
Thank you. I tried it. ( for 5 of them. trial version)
Message 26 of 41
k005
@pbejse
In one word, Super!
Thank you so much . Exactly as I want. my friend.
Message 27 of 41
pbejse
Thank you for letting me know it works for you.  There's one more thing we can do.
      (setq n (apply '*
        (strcat "(" (rtos (* n 0.0001) 2 (1+ (fix (/ (log n) (log 10)))) ) " m²)")
    )(princ)
That should take care of the decimal precision.
HTH
Message 28 of 41
k005
@pbejse
Very good... , Thank you very much. 🤗
Message 29 of 41
k005
Hi@pbejse
How should we change the code so that we can operate both with and without parentheses in this code?
I made a few code changes but without success.
Message 30 of 41
pbejse
We can cerainly make it work for both formats, but as always, i need a sample drawing of what is and what it will be
[ before / after ] for both conditions so there will be no confusion.
Message 31 of 41
k005
@pbejse
I attached the file
Message 32 of 41
pbejse
(Defun c:TrueSize ( / _Clean _WantedList ss str new_str)
(Defun _Clean (Str)
       (foreach itm '(("(" "") (")" "")(" " "")("/" " "))
		(setq str (Vl-string-subst (cadr itm) (car itm)str))))
(defun _WantedList (str / val p )
	(if
	  (and
	  	(vl-some  '(lambda (d)
		    (setq p (vl-string-position d str))) '(40 32)
	  	(setq n (apply '*
			  (read (strcat  "(" (_Clean (substr str (1+ p))) ")"))
	 (strcat  (rtos (* n 0.0001) 2 (1+ (fix (/ (log n) (log 10)))) ) " m²")
  (if (setq ss (ssget "_:L" '((0 . "TEXT")(1 . "*(*#/#*),* *#/#*"))))
    )(princ)
HTH
Message 33 of 41
k005
@pbejse
Thank you so much my friend. It's ok. 🤗
Message 34 of 41
k005
@pbejse
I exaggerated a bit, but can we just add a format like "30/60" to the list?
Message 35 of 41
pbejse
I suggest for now please look for other conditions that you might have overlooked.
Reply back only if you are sure you got every format covered.
Message 36 of 41
k005
@pbejse
Now when I say every form... Actually, there is no other form for now. I have 3 formats in total...
Message 37 of 41
pbejse
A quick mod
(Defun _Clean (Str)
	(if
	  (and
	  	(or
			   (if (setq p (vl-string-position d str))
			      	(setq str (substr str (1+ p)))))
				 '(40 32))
	    	(wcmatch str "#*/*#"))
	  	(setq n (apply '*
			  (read (strcat  "(" (_Clean str) ")"))
  (if (setq ss (ssget "_:L" '((0 . "TEXT")(1 . "*(*#/#*),* *#/#*,#*/*#"))))
      (if
    )(princ)
HTH
Message 38 of 41
k005
@pbejse
In one word, Super!.
Thank you very much. It's ok.
thanks my friend. 🤗
Message 39 of 41
k005
Hi@pbejse
How can we print the total area without breaking these formats?
S103 30/80
S103 (30/80)
30/80
Message 40 of 41
pbejse
Command: TrueSizer
