pedit and concrete volume
k005
Advisor Advisor
Message 1 of 15
k005
Hello friends;
How can I select line-arc or lwpolyline objects, make a "pedit", enter the mold height and print the result as a text
object on the drawing?
Replies (14)
Message 2 of 15
hak_vz
Try this code. I use boundary instead of pedit.
(defun c:cvol (/ *error* pt h a th)
	(defun *error* ( msg )
		(if (not (member msg '("Function cancelled" "quit / exit abort")))
			(princ)
		(setvar 'cmdecho 1)
		(princ)
	(setvar 'cmdecho 0)
	(setq th (getreal "\nText height >"))
	(while (setq pt(getpoint "\nPick a point inside bounding elements >"))
		(command "_.bpoly" pt "")
		(setq
			h (getreal "\nMold height >")
			pt (getpoint "\nText insertion point >")
			a (rtos(* h (vlax-get(vlax-ename->vla-object (entlast)) 'Area))2 2)
		(entdel (entlast))
		(entmake
		  (list
			(cons 0 "TEXT")
			(cons 10 pt)
			(cons 40 th)
			(cons 1 a)
	(setvar 'cmdecho 1)
	(princ)
Miljenko Hatlak
Message 3 of 15
k005
@hak_vz
it was very good.
How can we change the selection to window?
Also, it would be much better if it was taken from the Text height: textsize variable.
Thank you.
Message 4 of 15
hak_vz
Here is updated version
Point of text insertion is the one you pick inside bounding elements.
Text height is replaced with textsize variable.
I would stay with creation of temporary boundary element. There is option with pedit but it don't assure to collect and join all selected entities. Command join is also an option (better) but it modifies first entity in a set and don't create new entity. This seams to me is the fastest version.
Final area text string can be modified using autolisp strcat function with variable a that holds area string.
			(princ)
		(setvar 'cmdecho 1)
		(princ)
	(setvar 'cmdecho 0)
	(setq th (getvar 'textsize))
		(setq
		(entdel (entlast))
		(entmake
		  (list
			(cons 0 "TEXT")
			(cons 10 pt)
			(cons 40 th)
			(cons 1 a)
	(setvar 'cmdecho 1)
	(princ)
Miljenko Hatlak
Message 5 of 15
k005
@hak_vz
If we can change the code in this section to : Window. It'll be super.
The reason: to select small size objects without borders. this way it's fast. But it also calculates the Outer frame... whereas only the Inner Frame is required.
(setq pn1 (getpoint "\nÜst köşe?"))
(setq pn2 (getcorner pn1 "\nAlt köşe?"))
;(setq pt (ssget "W" pn1 pn2))
(while (setq pt (ssget "W" pn1 pn2))
Message 6 of 15
hak_vz
Attach sample drawing.
Miljenko Hatlak
Message 7 of 15
k005
@hak_vz
sorry. While I was writing in the other thread, I couldn't notice it..
I added the drawing.
Message 8 of 15
hak_vz
Ok. In your sample you have a lot of rectangles representing colons.
Explain how you want volume to be calculated.
Do you have some outer boundary and volume is area of this boundary minus area of internal entities times mold height?
Miljenko Hatlak
Message 9 of 15
k005
@hak_vz
Yes. there is no limit. but if we're going to treat it as a border, it's the area of the inner objects times the die height.
Message 10 of 15
hak_vz
@k005 wrote:
..... it's the area of the inner objects times the die height.
This is something completely different.
(defun c:cvol (/ *error* pt e h a  ss)
			(princ)
		(setvar 'cmdecho 1)
		(princ)
	(setq e (entlast))
	(princ "\nSelect entities >")
	(setq ss (ssget '((0 . "*LINE,ARC"))))
	(setvar 'cmdecho 0)
	(command "_pedit" "m" ss "" "y" "j" "" "")
	(setq ss (ssadd))
	(while (setq e (entnext e))(setq ss (ssadd e ss)))
	(setq i -1 a 0)
	(while (< (setq i  (1+ i))(sslength ss))
	(setq e (vlax-ename->vla-object (ssname ss i)))
	(if (vlax-property-available-p e 'Area)(setq a (+ a (vlax-get e 'Area))))
	(setq h (getreal "\nMold height >"))
	(setq pt (getpoint "\nText insertion point"))
	(entmake
	  (list
		(cons 0 "TEXT")
		(cons 10 pt)
		(cons 40 (getvar 'textsize))
		(cons 1 (rtos (* h a) 2 2))
	(princ (strcat "\n Volume = " (rtos (* h a) 2 2)))
	(setvar 'cmdecho 1)
	(princ)
Miljenko Hatlak
Message 11 of 15
k005
@hak_vz
Thank you very much. that's exactly what it is.
Message 12 of 15
Sea-Haven
An alternative method, make a dummy layer, draw a random pline around the objects, do bploy, all shapes will be made into plines, erase outside dummy layer. Note I dont think gcen is supported in Bricscad.
; label random pline areas
; By AlanH July 2021
(defun c:plarea ( / pl oldlay pt ent1 obj ss x a h)
(defun pl ()
	(setq pt (getpoint "\nStarting point  use \"C\" to exit : "))
	(command-s "_.pline" pt)
	(princ)
(setq oldlay (getvar 'clayer))
(command "-layer" "M" "dummy" "C" 4 "dummy" "")
(setq h (getreal "\nMould height >"))
(pl)
(setq entl (entlast))
(setq pt (getpoint "\nPick point inside"))
(command "Bpoly" pt "")
(command "erase" ent1 "")
(setq lst (mapcar 'cdr (vl-remove-if-not '(lambda (x) (= (car x) 10)) (entget (entlast)))))
(setq ss (ssget "WP" lst '((8 . "dummy"))))
(repeat (setq x (sslength ss) )
	(setq obj (vlax-ename->vla-object (ssname ss (setq x (1- x)))))
	(setq pt (osnap (vlax-curve-getStartPoint obj) "gcen"))
	(setq a (vla-get-area obj))
	(entmake
	  (list
		(cons 0 "TEXT")
		(cons 10 pt)
		(cons 8 oldlay)
(setvar 'clayer oldlay)
(command "-laydel" "N" "dummy" "" "Y")
(princ)
(c:plarea)
Message 13 of 15
Sea-Haven
Gcen is supported in Bricscad V20 just double checked, my previous attempt must have had incorrect syntax, thanks Kent for one that works.
Instructions.
Message 14 of 15
k005
@Sea-Haven
Yes, this is a very good alternative work.
* Can we just add a little: keep it that way. Get a total only at the point we click first or to another point.
Message 15 of 15
Sea-Haven
If you want just a total answer look at Hak_vz code and change mine where it does the get area and just write the answer as 1 text as in the Hak_vz code. A good place to start to learn about lisp.
