image_button problem
SAPER59
SAPER59
I have a problem in a 64 bit dcl that the image sometimees is filled and others don't without any reason
Even more it seems the square to be filled seems to doesn't exists,
I have read that is a problem with 64 bits system, any idea about how to make it works normally
Offcourse to fill it I do with:
(start_image sld)
(fill_image 0 0 (dimx_tile sld) (dimy_tile sld) color)
(end_image)
so is not a code problem
Thanks in advance
diagodose2009
In old times, I made w32vslide.vlx and w32vslide.exe.
I recommend you test your fies.slides with the w32vslide.exe, is very-fast directly inside windows10.
Also, you can check with w32vslide.vlx
Perhaps you have a problem with the "calibration"-position.(x,y=poz and zoomfacttor)
You can calibration with the "w32vslide.vlx" with Q2[enter] at line-command.
SAPER59
Thanks Diago but my problem is that in the DCL the square to display a filled colored image that will let the user change a color, dissapears, as if it doesn't exists,
And I have realized that even dcl start position is ignored even if you have save it, it always open the dcl in center of the window . Th epoint is strange because is didn't happen before
(if #pdistr1
(setq ok1 (new_dialog "asignotipo" #TROG_DCL "" #pdistr1))
(setq ok1 (new_dialog "asignotipo" #TROG_DCL))
(action_tile "accept" "(setq #pdistr1 (done_dialog 1))")
Thanks anyway
