Symbol name to a string?
Message 1 of 8
Does anyone know if you can convert a symbol name to a string?
Eg.
(setq str "(A B C)") => "(A B C)"
(setq lst (read str)) => (A B C)
(function-x lst) => ("A" "B" "C")
Thanks in advance!
Andrew Wilford
visualdcl@mindspring.com
Visual DCL v1.0
http://www.mindspring.com/~cwilford/visualdcl.htm
------------Millennium special $89.95!-----------
Replies (7)
Message 2 of 8
Vlisp: (vl-symbol-name symbol)
Using vanilla lisp you have to resort to writing to a temporary file and
then reading it back in.
__________________________________
Michael Puckett
programmer@cadvision.com
> Not < an Autodesk hall monitor.
Imagination makes all things possible.
"Andrew Wilford" wrote in message
news:38D2C652.84815964@mindspring.com...
Eg.
Thanks in advance!
Andrew Wilford
Visual DCL v1.0
Message 3 of 8
Regarding: (function-x '(A B C)) => ("A" "B" "C")
Using ...
(mapcar 'vl-symbol-name '(a b c))
should return
("A" "B" "C")
although I never tested it.
Michael Puckett
Eg.
Thanks in advance!
Andrew Wilford
Visual DCL v1.0
Message 4 of 8
Thanks Michael!
Although I am familiar with VL it is for a client who only has plain
lisp. I didn't think there was an easy way.
Thanks again.
Andrew Wilford
Visual DCL v1.0
Message 5 of 8
Don't give up man - it is easy.
(defun sym2str (sym / n f rtn)
(setq rtn "" n (strcat (getvar "tempprefix") "sym2str.tmp"))
(cond
( (setq f (open n "w"))
(prin1 sym f)
(setq f (close f))
(if (setq f (open n "r")) (setq rtn (read-line f) f (close f)))
rtn
eg (sym2str 'a) returns "A"
Michael Puckett
news:38D2D6BA.1CA7E8D1@mindspring.com...
Thanks Michael!
Thanks again.
Andrew Wilford
Visual DCL v1.0
Message 6 of 8
There's no need for opening a file (and leaving it cluttering up the
disk) in plain AutoLISP:
;;; Convert a symbol to its name as a string.
;;; Jon Fleming April 25, 1998 - based on code attributed
;;; to Bill O'Neal
;;; WARNING: DO NOT "compile" this function, in Visual
;;; LISP or Vital LISP, with "link" or "drop" options on!
(defun SymToStr (SymbolName)
;; If the argument is a symbol ...
(if (= (type SymbolName) 'SYM)
(progn
;; Execute the function we are going to create ...
;; Create a function on the fly
(list
;; The argument and local variable list. Note
;; that SymbolName will be evaluated, so the
;; symbol name that we're trying to convert
;; will be a local variable.
(list '/ SymbolName)
;; Set the local variable to 0 to make sure it
;; appears in the atoms-family (variables that
;; are "bound to NIL", explicitly or implicitly,
;; do not appear in the atoms-family)
(list set (quote SymbolName) 0)
;; In "native "AutoLISP", the symbol would
;; now be the first one in the atoms-family
;; list. Not so in Visual LISP. So we have
;; to look up the symbol [as a symbol] using
;; (member ...), compute its position in the
;; list, and then extract it from the string
;; version of the atoms-family list. This
;; also sets up the return value.
(list nth
(list -
(list length (list atoms-family 0))
(list length
(list member
(list (quote quote) SymbolName)
) ;_ end list
) ;_ end list
) ;_ end list
(list atoms-family 1)
) ;_ end list
;; End of the dynamic function
) ;_ end list
) ;_ end progn
;; If the argument is not a symbol, return NIL
nil
) ;_ end if
) ;_ end defun
jrf
Member of the Autodesk Discussion Forum Moderator Program
Message 7 of 8
Very clever. I remember this code being posted awhile ago. I had run it
and found it didn't work, tho that may have been a problem at my end.
Anyway, it works fine this time, and once all the comments are removed it's
quite tight - good one.
Speaking of using atoms-family ...
; michael puckett 2000/03/18
(defun sym2str (sym / str)
(if (eq 'sym (type sym))
(cond
( (eval sym)
(cdr
(assoc sym
(mapcar
'cons
(atoms-family 0)
(atoms-family 1)
( t
(set sym t)
(setq str (sym2str sym))
(set sym nil)
str
(sym2str 'abc) returns "ABC"
Michael Puckett
"Jon Fleming" wrote in message
news:VA.00000c22.0ab11d4b@fleming-group.com...
Message 8 of 8
Thanks guys!
Very clever indeed! I think he can manage that.
Andrew Wilford
Visual DCL v1.0
