suppressing regen notification
Ranjit_Singh
Advisor Advisor
Ranjit_Singh
I have a lisp routine which works fine. However, I cannot keep the command prompt clear while the LISP is running. It always displays this message "Restoring cached viewports - Regenerating layout." I have set cmdecho to 0 and it seems to suppress all the prompts ,but that one. Is there some other variable that needs to be tweaked? Thanks.
hmsilva
Try to set NOMUTT to 1 and back to 0 after...
Hope this helps,
Henrique
Ranjit_Singh
works perfect! Thanks!
hmsilva
You're welcome, Ranjit.Singh
Glad I could help
Henrique
Ranjit_Singh
In one other LISP that I am working on, I run Audit and Purge commands. Is there a way to suppress those messages. I have already tried cmdecho and nomutt. See screenshot below. Thanks.
hmsilva
Hi Ranjit.Singh,
supress the Audit prompts, I think it is not possible, even using the AuditInfo method, but the Purge prompts may be suppressed using the PurgeAll method.
Hope this helps,
Henrique
